vtec cutoff at 6500
Old Jun 3, 2004 | 08:32 PM
c1civic's Avatar
Default vtec cutoff at 6500
searched for along time, no answer
jsut got my h22 in my eg running. when i drive it, vtec kicks in, but i hit a cutoff at 6500 and my tach bounces. Im gettin a egr code, (runnin a p13) but i dont have everything to hook it up correclty. i also failed my nox by 1500. which i guess means i have carbon buildup. So my freind came over who has a chipped ecu and with that in my car, it ran fine, pulled all the way to redline. So we thought my ecu was bad. so we tried my ecu in his car, but it ran perfect, so we were kinda confused.
then yesterday i was takin it back to the paintshop to get touched up and i got on it, and it ran fine..with my ecu. I was happy thinkin it somehow fixed it self. Tried again 5 minutes later and it took at **** at 6500
my question is what could be wrong? im considering trying some sea foam. i want to figure this out because i am planning on spraying and afraid it will blow if this is not figured out
also my mods are intake, exahust, walbro 190, and a vafc
Old Jun 3, 2004 | 08:35 PM
LudeDewd's Avatar
Default Re: vtec cutoff at 6500 (c1civic)
check ure oil level, perhaps.
Old Jun 3, 2004 | 09:14 PM
red97prelude's Avatar
i would say to check the oil cause in my lude when vtech isnt hitting right im usually low on oil
Old Jun 3, 2004 | 10:38 PM
99BlackSH's Avatar
Default Re: vtec cutoff at 6500 (red97prelude)
Had the same prob.
Make sure your car is up to temp, check oil levels,
If those aren't it, then you may want to bring it into the dealership or any honda specialty shop. I hear that a leak in your VTEC filter could cause the same things. But I've never run into it personally.
Old Jun 4, 2004 | 05:01 AM
c1civic's Avatar
well oil is not the problem, i have checked it multiple times and its been good. as for being warmed up, i always let it warm up. but the only time it actually didi work, i tried 5 minutes alter an nothing..................does anyoen know all the things that must be present for vtec to work?
Old Jun 4, 2004 | 05:13 AM
Nick M's Avatar
Default Re: (c1civic)
6500 is "safe" mode or limp mode. How do you know you are getting vtec? You might just be hearing the secondary intake runners.
Old Jun 4, 2004 | 07:00 AM
c1civic's Avatar
i have the secondaries open all the time. it sounds diff and pulls harder, so im pretty sure it kickin in...also jsut put a new vtec filter screen on it, and that didnt do the trick
Old Jun 4, 2004 | 12:16 PM
LudeyKrus's Avatar
If you're sure VTEC's kickin in but the rev limit's at 6500, check the wiring for the VTEC oil pressure sensor.
i was wirin up an H22 into an Si w/ a VAFC the other day and after we got the wiring sorted out, it still had VTEC w/ a low rev limit. We finally figured out the connection into the ECU for the oil pressure wire was not good, so we jammed it in good and taped it down and it's been fine since.
Old Jun 4, 2004 | 12:34 PM
prelittlelude's Avatar
i can almost garentee that your not hitting vtec. hell try unpluging the vtec solinoid and then driving the car and see if it sounds / feels the same
vtec stuff i have accumulated
https://honda-tech.com/zerothread?id=830163
Old Jun 4, 2004 | 01:23 PM
c1civic's Avatar
thanks for the inputs i get my car back tomorrow, i will unplug the sensor and see if it feels diff
Old Jun 4, 2004 | 02:37 PM
LudeyKrus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c1civic &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the inputs i get my car back tomorrow, i will unplug the sensor and see if it feels diff</TD></TR></TABLE>
Good luck
rexload
Engine Management and Tuning
13
Oct 23, 2010 12:07 PM
slo97coupe
Feb 11, 2007 03:00 PM
c1civic
Jun 1, 2004 07:46 PM
Prelude Styl
Mar 20, 2004 08:13 PM
311
Oct 2, 2002 04:06 AM
