Time for suspension upgrade, What should I get???
I just got my 01' s2k. It was a nice upgrade from the EP3. Right now I have kg/mm springs, but I think once I get aftermarket wheels I will want to have less wheel gap. Should I go with coilovers for a street car. Or should I buy a different set of springs??? Any suggestions would be appreciated.
what's your budget like? If your car is a daily driver and you wont be messing around with ride heights, go for the koni yellows and keep your springs. The koni's have a lower spring perch that lowers the car about an inch (depending on the springs you use). They aren't expensive and work well.
- I ordered new suspension, koni yellows with comptech adjustable springs...
- no feedback yet because I don't have anything, im just going for dumpness anyways...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor »</TD></TR><TR><TD CLASS="quote">what's your budget like? If your car is a daily driver and you wont be messing around with ride heights, go for the koni yellows and keep your springs. The koni's have a lower spring perch that lowers the car about an inch (depending on the springs you use). They aren't expensive and work well. </TD></TR></TABLE>
That sounds like a good idea. Does anyone have pictures of this setup????? That being kg/mm springs and koni yellows.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dut619 »</TD></TR><TR><TD CLASS="quote">JMS JT: pics with buddyclubs..?
I'll take one sometime this week then.
