Brake Booster Question... Having some Troubles, Need some Ideas
Old Jun 3, 2004 | 06:24 PM
ED9B16A's Avatar
Default Brake Booster Question... Having some Troubles, Need some Ideas
I replaced the booster on my Crx about 3months ago, Ive noticed that the brakes are sticking now. I tried to set it similar to my oem one, but I guess it didnt work out.
When you disconnect the booster Vac line, the wheels will release. When connected and the brake is pumped up they start sticking again.
Ive adjusted it all the way out, then in, and nothing has changed. Still sticks
Think its bad? The Check valve is Good. It Hiss's air out when I pull the valve out like its not relasing the pressure.
btw its an autozone part.....
Ive got a really bad wobble also, my rotors are shot. Do you think the brakes sticking to warped rotors would cause a wobble to start around 60-90? occurs w/o braking or throttle.
Modified by ED9B16A at 3:44 AM 6/4/2004
Old Jul 14, 2004 | 10:02 AM
killa_lude's Avatar
Default Re: Brake Booster Question... Having some Troubles, Need some Ideas (ED9B16A)
im experiencing the same problem..im just going to get a new booster.
ED9B16A
Jun 4, 2004 04:40 PM
ED9B16A
Jun 4, 2004 04:38 PM
ED9B16A
Jun 4, 2004 04:37 PM
pablo_max
Oct 23, 2002 04:32 PM
Heavy Pee
Sep 17, 2002 01:27 PM
