Brake Booster Question, Havin some troubles..need some Ideas
Old Jun 3, 2004 | 06:23 PM
ED9B16A's Avatar
Default Brake Booster Question, Havin some troubles..need some Ideas
I replaced the booster on my Crx about 3months ago, Ive noticed that the brakes are sticking now. I tried to set it similar to my oem one, but I guess it didnt work out.
When you disconnect the booster Vac line, the wheels will release. When connected and the brake is pumped up they start sticking again.
Ive adjusted it all the way out, then in, and nothing has changed. Still sticks
Think its bad?
btw its an autozone part.....
Ive got a really bad wobble also, my rotors are shot. Do you think the brakes sticking to warped rotors would cause a wobble to start around 60-90? occurs w/o braking or throttle.
Old Jun 3, 2004 | 06:38 PM
Jaker's Avatar
Default Re: Brake Booster Question, Havin some troubles..need some Ideas (ED9B16A)
The check valve in your booster vaccumm feed could be backwards, and causing the booster to be "overboosted", or maybe there's a check valve in the booster itself that is not releasing the pressure when you let the brake pedal go. Or I could be talking out my ***, as I'm really not that familiar with the inner workings of the booster.
Old Jun 3, 2004 | 06:43 PM
ED9B16A's Avatar
Default Re: Brake Booster Question, Havin some troubles..need some Ideas (Jaker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">The check valve in your booster vaccumm feed could be backwards, and causing the booster to be "overboosted", or maybe there's a check valve in the booster itself that is not releasing the pressure when you let the brake pedal go. Or I could be talking out my ***, as I'm really not that familiar with the inner workings of the booster. </TD></TR></TABLE>
I checked the valve, looked to see it was facing correct direction, blew threw it, replaced it an extra. Its good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jaker &raquo;</TD></TR><TR><TD CLASS="quote">check valve in the booster itself that is not releasing the pressure </TD></TR></TABLE>
How do I do that? Its not releasing the pressure. WHen I pull the Valve out it hiss's air out like a champ.
Old Jun 3, 2004 | 09:15 PM
CWESTINAP1's Avatar
i had this problem before too. unfortunately my solution was to go back to a stock crx bb and mc. i got the 4040 prop valve in tho.
Old Jun 4, 2004 | 04:40 PM
ED9B16A's Avatar
Default Re: Brake Booster Question, Havin some troubles..need some Ideas (CWESTINDC2)
Anyone here of a Brake Booster sticking?
Specail Ed
Jun 23, 2019 12:03 PM
gophat
Jan 7, 2007 05:32 PM
ED9B16A
Jul 14, 2004 10:02 AM
ED9B16A
Jun 4, 2004 04:38 PM
veejay
Jul 24, 2001 09:39 AM
