tranny grinds
Old Jun 3, 2004 | 06:09 PM
frknlo87's Avatar
Default tranny grinds
when i shift from 2nd to 3rd and 3rd to 4th it grinds. what the hell is wrong with it. im a newbie so go easy on me.
Old Jun 3, 2004 | 06:15 PM
fasterthanU's Avatar
Default Re: tranny grinds (frknlo87)
it happens to every tranny after awhile. start with the cheapest thing first: bleed the clutch slave cylinder if you've got a hydralic clutch, if that doesn't do it then change the clutch and if that doesn't do it the get your tranny rebuilt or buy a new one the synchros are shot.
Old Jun 3, 2004 | 06:17 PM
Frankintegra's Avatar
Your syncros are dammaged! tou will need new brass rings. These brass ring help slow the gears down so that you can have smooth engagement of your gears. If you did what I did and use synthetic oil in the tranny it is probably your dog teeth that is messed! Do no use Synthetic it is to slick for the brass rings. Only use what Honda recommends. You can get a used tranny or get your brass ring replaced.
Hope this helps!
Old Jun 3, 2004 | 06:21 PM
thaiphob's Avatar
Nikon!!!
Default Re: tranny grinds (Frankintegra)
id say before going through the headache of replacing your syncros, just change your tranny fluid first.
smoked08
Jan 11, 2012 06:28 PM
mugen si
Transmission & Drivetrain
Apr 8, 2009 09:41 PM
delsold16
Sep 22, 2004 07:19 AM
Proper
Apr 23, 2003 04:55 PM
STaNkFaNgaZ
Nov 13, 2002 07:00 AM
