help clutch master cylinder
Old Jun 3, 2004 | 03:36 PM
92civic_eg's Avatar
Default help clutch master cylinder
hello my friends
I need to change my clutch master cylinder for a 96 integra , but i dunno how to do it, because it is more compicated than civic! any tips ? or suggestion
Btw should I buy a after market master cylinder ??
Old Jun 3, 2004 | 04:19 PM
Brian_TII's Avatar
Default Re: help clutch master cylinder (92civic_eg)
I would expect it to be the same or similar to your Civic. Basically all you do it unhook the resovior hose, un-bolt the clutch master cylinder (under the dash), un-do the cotter pin and release the clutch pedal from the shaft, un hook the hydrulic line (under the hood) and then take it out... installation is the reverse of removal, except that you have to bleed the system after you put it back together
It's pretty easy really... what part do you not understand? If you had specific questions it would be easier to answer you.
Good luck and let us know if you need more help.
Old Jun 3, 2004 | 05:23 PM
tilt's Avatar
it's a pita getting the cotter pin out. i had to lay on my back and get to it. other than that it is pretty simple and self explanatory.
Old Jun 3, 2004 | 06:50 PM
92civic_eg's Avatar
Default Re: help clutch master cylinder (Brian_TII)
thanks brian u have a nice day
Ajr
Honda S2000
Sep 21, 2014 11:24 AM
rollercosta123
Jan 2, 2006 02:11 PM
siregcivic
Oct 16, 2005 07:55 PM
