VAFC II Intial Setup
Old Jun 3, 2004 | 03:14 PM
ShuaiGuy's Avatar
Default VAFC II Intial Setup
Hey guys sorry for the dumb question, but I've searched an have been able to find a definitive answer. How do I set the intial settings on VAFC II with stock ecu? ie... Number of sensors, voltage, vtec type, throttle pos? If someone could walk me through it would be greatly appreciated. I thought I did it right, but for someone reason my gas mileage has dropped tremendously. TIA!
Old Jun 3, 2004 | 05:07 PM
Misfit's Avatar
Default Re: VAFC II Intial Setup (ShuaiGuy)
RTFM...
Read The Fuggin Manual..
actually I think there is a whole section in there that is dedicated to initialization... If you don't have the manual... Look on the website.. there is bound to be a pdf file to download.
Old Jun 3, 2004 | 05:33 PM
Fuuma0083's Avatar
Default Re: VAFC II Intial Setup (misfit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by misfit &raquo;</TD></TR><TR><TD CLASS="quote">RTFM...
actually I think there is a whole section in there that is dedicated to initialization... If you don't have the manual... Look on the website.. there is bound to be a pdf file to download. </TD></TR></TABLE>
It's on pg 12-13
Turn on the ignition switch
set Sensor No. 6 - 6
Cyl. 4 Throttle up and VT on 1(but doesn't matter for VT if your going to set your own rpm ranges)
Learning the Throttle Opening
Leave the throttle closed for 10 secs (off the gas pedal)
Open throttle for 10 secs (get on the gas pedal to the floor)
Sensor Chk
check when throttle is fully closed (off the gas pedal) the voltage is between 0V-1V
check when throttle is fully open (on the gas to the floor) the voltage is between 3V-5V
Turn the ignition switch Off
Your done.
Modified by Fuuma0083 at 9:45 PM 6/3/2004
Old Jun 3, 2004 | 08:00 PM
Runnerdown's Avatar
Default Re: VAFC II Intial Setup (Fuuma0083)
What does that mean? I am trying to set one up and I don't understand what this represents.
Old Jun 4, 2004 | 05:58 AM
ShuaiGuy's Avatar
Default Re: VAFC II Intial Setup (Runnerdown)
hey guys thanks... also another question i should have asked! there were some extra wires for the i-vtec. i just taped it off. is this correct or should i have pulled it off completely?
VTEC_PRODUCTION
Mar 25, 2007 12:50 PM
jdmh22luda
Jul 23, 2005 09:06 AM
ShuaiGuy
Jun 4, 2004 10:02 AM
LUDExCONDUCT
Apr 15, 2004 09:53 AM
adam_ae86
Aug 27, 2003 06:10 PM
