Stock B16 header off a 99-00 si same as b16 header off xsi integra?
I think its the same length, the only thing I could see being different would be that O2 sensor positions. I could be wrong on this but most headers are the same length, just differnet heights.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kevedge »</TD></TR><TR><TD CLASS="quote">I think its the same length, the only thing I could see being different would be that O2 sensor positions. I could be wrong on this but most headers are the same length, just differnet heights.</TD></TR></TABLE>
So should a stock gsr header and stock si header be the same length?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96gsr4dr »</TD></TR><TR><TD CLASS="quote">
So should a stock gsr header and stock si header be the same length? </TD></TR></TABLE>
the "length" should be the same, but not the height. So I think that a gsr header will fit an si, but an si header wont fit a gsr, im not sure about that. I have a header meant for a gsr, and it hangs really low because the GSR's have a higher deck height. So if I were to put the header on a gsr, it would level out.
the "length" should be the same, but not the height. So I think that a gsr header will fit an si, but an si header wont fit a gsr, im not sure about that. I have a header meant for a gsr, and it hangs really low because the GSR's have a higher deck height. So if I were to put the header on a gsr, it would level out.</TD></TR></TABLE>
Oh i see. Thanks
Oh i see. Thanks
aamadeus
17
Feb 26, 2005 07:31 PM
whitemike1644
Jun 10, 2003 10:45 PM
