Sucked up a piece of platic!!!!!!!
Old Nov 11, 2001 | 06:14 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Sucked up a piece of platic!!!!!!!
I was checking my AEM bypass valve today when I notice one of the small center pieces to be missing. Since it has the little foam filter around it, I'm thinking that it was most likely sucked into the engine. The piece is about 1/2" long and a couple of mm thick. Could this do any serioud damage or will the engine just burn it up? Thanks in advance.
Old Nov 11, 2001 | 06:16 PM
RacerXI's Avatar
Default Re: Sucked up a piece of platic!!!!!!! (ActiveAero)
That's not good. If it's that big, it could possibly get stuck in your TB and keep it open. Try taking the aem off to see if it's somewhere in the tube.
Old Nov 11, 2001 | 06:17 PM
CPR's Avatar
CPR
I don't have an AEM but I thought that they sent out a bulletin a while back regarding a defect of the bypass valve. The defect is exactly how you described what happened to yours.
Hybrid ctr's Avatar
this could do serious damage
your in trouble
Old Nov 11, 2001 | 06:19 PM
CPR's Avatar
CPR
Default Re: Sucked up a piece of platic!!!!!!! (CPR)
Here you go bud
https://honda-tech.com/zerothread?id=49330
Old Nov 11, 2001 | 06:27 PM
Ross's Avatar
25 Year Member
Community Builder
Active Streak: 30 Days
Aero - as much **** as I give you, I'm about to give you some sound advice. Get a Comptech Icebox. It will save you the headache. I went rally driving with mine in Cape Cod and got muddy water spattered all over my engine bay. If I'd had an AEM...I dont even want to think about it.
Old Nov 11, 2001 | 07:55 PM
d8168055's Avatar
go get the "ring." call AEM and they will send it in like 2 days...
dohc_profile
Oct 11, 2007 04:48 PM
5-SpeedFreak
Dec 23, 2002 12:33 PM
friedsqrl
Aug 20, 2002 09:48 AM
Hard2Find
Mar 14, 2002 11:06 AM
George H
Oct 11, 2001 10:16 PM
