Battery light
Old Jun 3, 2004 | 01:42 PM
_bB's Avatar
_bB
Default Battery light
Hey I have a 1991 Civic with B16A and whenever I am driving my battery light stays on most of the time, and I figured the car isnt chargin while its running, but sometimes when im driving the battery light will turn off and stay off for a while until I make a turn or hit a bump or something along those lines.
Does anyone have any idea what could be causing this problem??
Old Jun 3, 2004 | 01:45 PM
murtnabila's Avatar
Default Re: Battery light (SleepingB16Hatch)
could be:
alternator
loose connection
weak ground
Old Jun 3, 2004 | 03:14 PM
Ekasey's Avatar
Default Re: Battery light (murtnabila)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murtnabila &raquo;</TD></TR><TR><TD CLASS="quote">could be:
alternator
loose connection
weak ground</TD></TR></TABLE>
use a dvom at the battery to see if it is charging when the light is on then checkl to make sure all your connections are tight
Old Jun 11, 2004 | 05:52 PM
ceLtic's Avatar
N/A wh0re!
Default Re: Battery light (eLusive ek4)
i got the same problem on my crx. thing is, the alternator crapped out, replaced it, getting 12volts when the car is on, and when it is off. everything works, the battery light just stays on? why?
Old Jun 11, 2004 | 06:53 PM
Ekasey's Avatar
Default Re: Battery light (ceLtic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ceLtic &raquo;</TD></TR><TR><TD CLASS="quote">i got the same problem on my crx. thing is, the alternator crapped out, replaced it, getting 12volts when the car is on, and when it is off. everything works, the battery light just stays on? why?</TD></TR></TABLE>
you should be seeing near 14+ volts if the alternator is charging
slickrc
Dec 29, 2009 02:24 PM
pendejon
10
Apr 27, 2006 01:22 PM
whitehf
May 20, 2005 09:32 AM
pane93civhb
Sep 18, 2004 01:39 PM
iridebiketrials
Feb 16, 2004 03:01 PM
