gas seeping through fuel filter bolt.. need help.
Old Jun 3, 2004 | 12:34 PM
typeeg's Avatar
Default gas seeping through fuel filter bolt.. need help.
I just checked under the hood and i noticed that the bolt that holds the fuel line which leads tot he fuel rail was wet with gas.. i wiped it clean and then turned on the motor again and i notice oil is seeping through where the bolt goes into the line. I tightend it as much as it could be still seeping. Any ideas why?
Old Jun 3, 2004 | 12:54 PM
JimBlake's Avatar
Default Re: gas seeping through fuel filter bolt.. need help. (StockEG9)
The washers above & below the banjo fitting have rubber seals inside. When they're shot it doesn't do any good to tighten the bolt. When you take it apart clean up the surfaces that they seal against, too. They should be flat, straight, & smooth.
Old Jun 3, 2004 | 01:12 PM
MightyMouseTech's Avatar
Default Re: gas seeping through fuel filter bolt.. need help. (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">The washers above & below the banjo fitting have rubber seals inside. When they're shot it doesn't do any good to tighten the bolt. When you take it apart clean up the surfaces that they seal against, too. They should be flat, straight, & smooth.</TD></TR></TABLE>
rubber seals??????
The PROPER seals are pure alluminum.
Just get two new seals and tighten down to the PROPER torque, tightening down the current ones will probably just make it worse.
Old Jun 3, 2004 | 01:17 PM
JimBlake's Avatar
Default Re: gas seeping through fuel filter bolt.. need help. (MightyMouseTech)
I guess I figured all banjo fittings were the same. The washers (on either side of the banjo) have rubber lips around their inside. That seals against the flat surfaces of the banjo & the filter. So Honda does it different? Either way, you don't re-use the washers.
Old Jun 4, 2004 | 11:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I guess I figured all banjo fittings were the same. The washers (on either side of the banjo) have rubber lips around their inside. That seals against the flat surfaces of the banjo & the filter. So Honda does it different? Either way, you don't re-use the washers.
You have been working on GM's too long.
Old Jun 4, 2004 | 11:28 AM
DaX's Avatar
DaX
Loved
Community Favorite
Replace the aluminum crush washers. They're similar to the one on your oil pan drain bolt, which you should also replace everytime you change your oil.
Old Jun 4, 2004 | 02:22 PM
typeeg's Avatar
Default Re: (DaX)
Fixed it. I put some teflon tape around the bolt threads and high temp silicon around the washers. Worked like a charm
Old Jun 6, 2004 | 07:04 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MightyMouseTech &raquo;</TD></TR><TR><TD CLASS="quote">You have been working on GM's too long. </TD></TR></TABLE>LOL! VW, Audi, Saab, & an older BMW...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">Fixed it. I put some teflon tape around the bolt threads and high temp silicon around the washers. Worked like a charm </TD></TR></TABLE> So that saved you, what, 90 cents worth of washers? I hope little bits of the teflon tape don't come off & plug your injectors.
Old Jun 6, 2004 | 07:14 AM
typeeg's Avatar
No it saved me a trip to Honda dealer which is 40 miles away from where I live. Sucks living in the boonies
and don't worry the tape wont plug up the injectors
Old Jun 7, 2004 | 11:41 AM
and don't worry the tape wont plug up the injectors </TD></TR></TABLE>
Yes, the tape WILL plug the injector if it gets that far.
Old Jun 7, 2004 | 12:41 PM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">No it saved me a trip to Honda dealer which is 40 miles away from where I live. Sucks living in the boonies </TD></TR></TABLE>OK, I guess I didn't think of that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockEG9 &raquo;</TD></TR><TR><TD CLASS="quote">and don't worry the tape wont plug up the injectors </TD></TR></TABLE>Next time just seal the washers. The threads on the banjo bolt don't seal anything. The washers are the pressure boundary.
Old Jun 7, 2004 | 01:33 PM
typeeg's Avatar
Yes, the tape WILL plug the injector if it gets that far.</TD></TR></TABLE>
and you know this how?
I didn't tape the entire thread, just the part where it holds onto the rim of the filter. If you take out the bolt you will notice it has a hole on the bottom and a hole on the side near the head of the bolt.. I taped just above that hole where it doesn't even dip into the fuel.. so please tell me how this will happen?
STLblackcivic
Mar 31, 2007 07:36 PM
tonezilla
Sep 11, 2004 04:33 PM
onePOINTsix
Sep 4, 2003 08:24 AM
Edward911
Feb 8, 2003 09:48 PM
95GS-R
Sep 5, 2002 03:47 PM
