JDM B16A Skunk2 IM install help
Old Jun 3, 2004 | 11:05 AM
JDM-Vic's Avatar
Default JDM B16A Skunk2 IM install help
I have a JDM B16A, and will be installing my new Skunk2 Intake Manifold today. What I would like to know is, is if there will be any problems I will run into while installing it. Like having to re-route any vacume lines or somthing like that.
Thanks.
Old Jun 3, 2004 | 11:43 AM
JDM-Vic's Avatar
ttt
Old Jun 3, 2004 | 02:24 PM
JDM-Vic's Avatar
Old Jun 3, 2004 | 08:55 PM
Kevedge's Avatar
Default Re: (JDM-Vic)
Im assuming thats its going into an OBD1 car since you have a 1993. It should all just bolt right up. Just unbolt your TB and leave it there, then pull off your intake manifold, put the new one on, then bolt the TB back on, then your set. Just make sure you have all the right gaskets, and take your time. I think you may have to plug up one hole in the back of the manifold, but im not sure if the skunk2 has it, I know the ITR manifold does when i put it on my B16. You may have to buy a new PCV valve because most people break theres because its hard to take out of the intake manifold. Also make sure to watch out for the knock sensor located underneath the intake manifold on the right side. I have had three friends break theres. Good luck!
sung
Sep 28, 2007 08:21 PM
red_honda_racer
13
Jan 16, 2004 11:16 AM
iTR.EX
Dec 17, 2002 06:05 AM
IA93Vteclude
Oct 8, 2002 12:09 PM
