Stock Spring Rates
Old Jun 3, 2004 | 08:38 AM
docmanakos's Avatar
Default Stock Spring Rates
I was interested in finding out the spring rates for the various Del Sol's.
I know their is a difference between the S, Si rates and the VTEC, I just don't know what the numbers are.
Do the civic's have interchangable suspension parts? Are the spring rates the same for all the Civic models as well as the Del Sol models?
What are the differences between the brakes, I know that the S's don't have rear discs. But is their a difference between the sizes of the fronts?
Also are the Integra front and rear similar to the Del Sol VTEC brakes?
Are any of the civic brakes similar?
Are there any steering rack differences between the various Del Sol models?
Do the Integra models have the same racks?
The last question, What are the sway bar dimensions for the VTEC Del Sol front and back?
Docmanakos@aol.com
Old Jun 3, 2004 | 09:19 AM
drkarrow's Avatar
Default Re: Stock Spring Rates (docmanakos)
With so many del sol specific questions, you may want to try and ask on a del sol specific message board. or you could look here for some info http://www.teamdelsol.com/technical/faq/
These are the aswers I can think of off the top of my head
92-95 civic suspensions are fully interchangable with all 93-97 del sols. for 96-00 civics not everything is compatible. but spring rates do vary depending on the model.
For del sol brakes look under #2 in the FAQ I linked above
For the rack, there was a manual rack option for the S model, all the rest had power. The manual rack is more turns lock to lock than the power rack. I think all the del Sol power racks are the same.
Old Jun 3, 2004 | 05:21 PM
.RJ's Avatar
.RJ
https://honda-tech.com/zerosearch
7rrivera7
Suspension & Brakes
Mar 11, 2012 08:02 AM
sshh
Suspension & Brakes
Dec 23, 2010 10:07 AM
airsodam
10
Nov 10, 2005 05:24 AM
DMF
Dec 12, 2003 09:50 AM
