ITR LCA's on an EG... which bolts, which hole for swaybar?
Old Jun 3, 2004 | 08:32 AM
ScubaStevo80's Avatar
Default ITR LCA's on an EG... which bolts, which hole for swaybar?
I'm putting these ITR LCA's on my EG soon. My questions are...
1. I figure I can reuse the bolts from the stock LCA's where the red arrow point correct?
2. What bolt (size, where to buy other than acura) do I need for where the shock connects to the LCA shown by the blue arrow?
3. Are the holes circled in green used for anything? Is one of these where the rear swaybar mounts?
Old Jun 3, 2004 | 08:48 AM
drunknbass's Avatar
youll only get them in the right one haha. but its the middl eone
Old Jun 3, 2004 | 09:08 AM
743power's Avatar
Default Re: (drunknbass)
you NEED to use acura suspension bolts. I used a bolt from home depot to hold my swaybar on, and it bent in half and stripped in a couple of hours.
Old Jun 3, 2004 | 09:29 AM
Default Re: (x743x)
Acura bolts for all three (blue and red)? Or just for the blue one? I'll check out acuraautomotiveparts.com unless anyone knows a better place to check.
My car (EG stock) appears to list 10x80 bolts for both the front and rear portions of the LCA while the acura type r parts appear to be 10x80 front and 10x89 rear. I cannot find the size for the bolts that hold the shocks on... anyone know for sure?
Modified by VolpeOwnsU at 2:26 PM 6/3/2004
Old Jun 3, 2004 | 10:41 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: (VolpeOwnsU)
I just used the stock Civic bolts... it worked fine....
wastedyouth2542
Jun 23, 2010 09:54 AM
ek9tl
Aug 20, 2007 04:35 PM
Paul1985
Suspension & Brakes
Jul 4, 2006 06:58 PM
Cliffjumper2
May 23, 2005 07:12 PM
mantic6t9
Jan 15, 2002 05:50 PM
