Big mistake need help
Old Jun 3, 2004 | 06:34 AM
ArgGuy's Avatar
Default Big mistake need help
i was tryin to change my own oil for the first time and i drained the wrong part i don;t know what i drained but i need to put it back in but i don;t know where to pour it in ...near the front left suspension ...here;s some pics... its a 2000 honda prelude non sh
Modified by ArgGuy at 4:15 PM 6/3/2004
Old Jun 3, 2004 | 06:36 AM
Jagan'92's Avatar
Default Re: Big mistake need help (ArgGuy)
You drained your ratchet? wow those pictures confuse me... i feel upside down.
what year is your car?, driver side suspension is kind of near the oil drain bolt. if you took off the driver's wheel, the bolt is facing the rear of the car, slightly angled down... below and to the left (driver side) of the oil filter. i can't tell you what you drained, though.
Old Jun 3, 2004 | 06:40 AM
ArgGuy's Avatar
Default Re: Big mistake need help (Jagan'92)
2000 honda prelude non SH...it;s in the front left side bottom...
Old Jun 3, 2004 | 06:50 AM
OTT's Avatar
OTT
Looks like youve drained the transmission fluid, the pictureof the suspension of from the front right hand side, so where you drained oil from was the driveshaft directly above it?
Old Jun 3, 2004 | 07:17 AM
ArgGuy's Avatar
Default Re: (OTT)
i think your right do you know where to pour the transmission fliud back into the car...it;s right beneath the car battery...it has it;s own little dip stick...
Modified by ArgGuy at 4:30 PM 6/3/2004
Old Jun 3, 2004 | 07:28 AM
OTT's Avatar
OTT
Id be surprised if it does haveits own little dipstick. Stay away from the battery you dont want to drain any other fluids from your car! =P
Where the drain plug is for the transmission that your drained, there is a little filler bolt that you remove that is inside the front right wheel well a bit higher than the centre of the driveshaft 'cup'.
This is the only fill point that should be used, its at a mounted vertically at a particular height so that if you overfill it the excess will just drain out. Is your car a manual? if it is then you eed to buy some manual transmission fluid, might as well change that since youve drained it. Aslo have you bought an oil filter? if you havent then you must go buy one, theres no point in changing your oil without changing the filter!.
Heres a pic of the two drain locations.
Old Jun 3, 2004 | 07:32 AM
ArgGuy's Avatar
Default Re: (OTT)
is there any way that i can call you...if your not busi right now...cauz i can;t exactly...drive anywhere...do you have a aim s.n.
Old Jun 3, 2004 | 07:34 AM
Jagan'92's Avatar
Default Re: (OTT)
And that's quick and professional.
If your car is an automatic, you will have a dipstick, and you can fill through the dipstick hole with a funnel. Otherwise - listen to the wise brit.
Old Jun 3, 2004 | 07:35 AM
OTT's Avatar
OTT
Im in England so bit far for you to call. My msn is supercharged_prelude@hotmail.com
Old Jun 3, 2004 | 07:36 AM
ArgGuy's Avatar
Default Re: (Jagan'92)
i was jus about to do that but wasn;t sure that it was okie...aite...thanks for your help...
Old Jun 3, 2004 | 09:12 AM
fastludeh22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jagan'92 &raquo;</TD></TR><TR><TD CLASS="quote">And that's quick and professional.
If your car is an automatic, you will have a dipstick, and you can fill through the dipstick hole with a funnel. Otherwise - listen to the wise brit.</TD></TR></TABLE>
Old Jun 3, 2004 | 10:36 AM
TeaLemonBrisk's Avatar
Default Re: (fastludeh22)
too funny... lol
Old Jun 3, 2004 | 01:55 PM
sushib01's Avatar
it is under-behind the block. the bolt is an obvious different color.
Old Jun 3, 2004 | 04:20 PM
vinuneuro's Avatar
what side of the car does the bolt face? You will know for sure then
Old Jun 3, 2004 | 05:38 PM
prelude1897's Avatar
Default Re: Big mistake need help (vinuneuro)
Lol, how could you get the transmission fluid drain mixed up with the oil pan drain?? Its kinda hard to mix those up
Old Jun 3, 2004 | 07:28 PM
SKDRCR's Avatar
Default Re: Big mistake need help (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">Lol, how could you get the transmission fluid drain mixed up with the oil pan drain?? Its kinda hard to mix those up</TD></TR></TABLE>
he didn't know what the oil pan looked like
Old Jun 4, 2004 | 01:09 AM
OTT's Avatar
OTT
Its just another classic HT moment.
Old Jun 4, 2004 | 02:32 AM
4bidden's Avatar
Default Re: (OTT)
Give the guy some credit, at least he is trying to do it himself. We were all there at one point or another, its just that most people dont have the ***** to post up and admit they made a mistake and ask for help.
Old Jun 4, 2004 | 04:47 AM
Doctor Who's Avatar
Is it me, or does his driver's side halfshaft look really greasy?
Old Jun 4, 2004 | 10:49 AM
del_parker's Avatar
Default Re: (Doctor Who)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doctor Who &raquo;</TD></TR><TR><TD CLASS="quote">Is it me, or does his driver's side halfshaft look really greasy?</TD></TR></TABLE>
besides the fact the boot is slid down the cv axle?
Old Jun 4, 2004 | 12:28 PM
OTT's Avatar
OTT
It was a torn up inner boot and the outer DOJ (double offset joint) was ceased, DOJ cannot be rebuilt s had to obtain a new one.
That driveshaft was stripped down for parts and then I rebuilt one and slung that in. You'll also notice theres no steering knuckles, the cradle in the car is sealed with rist proofing and thers old cradle bits in the background.
see Why here... https://honda-tech.com/zerothread?id=712816
Old Jun 4, 2004 | 12:29 PM
OTT's Avatar
OTT
and its my passenger side axle btw. Its a JDM machine.
wrestlerk20
Sep 2, 2011 07:44 AM
EK9 BEEZLER
Jan 15, 2007 08:30 PM
batistarocker
May 24, 2006 06:34 PM
LazyAzn
Dec 11, 2005 07:45 PM
damian0216
Oct 29, 2005 11:30 AM
