jdm b16 cams vs type r cams
USDM type r has more lift and duration compared to the b16a (jdm) BUT the Civic type r almost has the exact lift and duration except for the exhaust cams is has a little less compared to the USDM type r, the intake cams are the same.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quitripin »</TD></TR><TR><TD CLASS="quote">BUT the Civic type r almost has the exact lift and duration except for the exhaust cams is has a little less compared to the USDM type r, the intake cams are the same.</TD></TR></TABLE>
Actually, all CTR and ITR exhaust cams are virtually identical (though I'm not certain whether they share part numbers). The '00+ USDM ITR intake cam is also basically identical to the CTR's intake cam, while '97-'98 ITR intake cams have roughly 3 degrees less duration.
