What is the rpm when driving 60 mph????
Old Jun 2, 2004 | 09:57 PM
reithhikaru's Avatar
Default What is the rpm when driving 60 mph????
First i am new to this forum, hi all~!
My integra is a 91 GS A/T , the rpm is abnormal ( i think ) at 80 mph hit 4500rpm...
just wanna listen some opinions. Thanks!
Old Jun 2, 2004 | 11:24 PM
TrueUntilDeath.com's Avatar
Default Re: What is the rpm when driving 60 mph???? (reithhikaru)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reithhikaru &raquo;</TD></TR><TR><TD CLASS="quote">First i am new to this forum, hi all~!
just wanna listen some opinions. Thanks! </TD></TR></TABLE>
i think mines aroudn 4500 +/- 500 @ 80mph as well
98 ls manual
Old Jun 2, 2004 | 11:27 PM
AznJohn33's Avatar
Default Re: What is the rpm when driving 60 mph???? (C. FujiMoto)
yessss somebody's 1st post doesn't suck.
Mine's at 4k at 80mph, but we drive completely different cars. Eh.
Old Jun 2, 2004 | 11:54 PM
IVI's Avatar
IVI
Default Re: What is the rpm when driving 60 mph???? (AznJohn33)
sounds normal.
Old Jun 3, 2004 | 05:00 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: What is the rpm when driving 60 mph???? (IVI)
That's not normal, it's not shifting into overdrive (4th gear). Check to make sure you're in D4, and if so, then there is a problem causing the transmission not to upshift all the way.
Old Jun 3, 2004 | 05:13 AM
m R g S r's Avatar
Default Re: What is the rpm when driving 60 mph???? (PatrickGSR94)
Yea, espically in an auto LS, that's not normal. Even in my gsr, 80mph in 5th gear is around 4100rpm.
Old Jun 3, 2004 | 06:22 AM
RallyRedGT-V6's Avatar
Default Re: What is the rpm when driving 60 mph???? (m R g S r)
at eighty im at like 3800...i'm not doing 45k's until im at 100mph
Old Jun 3, 2004 | 07:01 AM
BlackSage's Avatar
Im using the gear ratio calulator from T-I
It says the following for a 1990-93 acua integra auto
80mph in 4th gear ~3750rpm
80mph in 3rd gear =5000rpm
So I dont think the problem is that you are in third gear. Maybe your speedo or your tach is off? Just my opinion Im not a transmission specialist.....
HTH
EDIT to answer your question the RPM at 60MPH is
5700rpm in 2nd
3750rpm in 3rd
2750rpm in 4th
These are not exact but they should be close.....+/- 250rpm
Old Jun 3, 2004 | 08:03 AM
Default Re: What is the rpm when driving 60 mph???? (BlackSage)
yes, the speedo cable may be a problem! i forget to tell this!
when i am on Interstate 95 at Maryland, i received a warning ticket from cop who said i was over 8 mph at 65 zone.....but i have crusie at 65+/-2mph! Damn at cop, wasted my time!
than ok...i tested today with another car on freeway, i followed him. when he was driving 65mph, my speedo is 55mph.....OMG
What is the problem of this occur? Thanks
Old Jun 3, 2004 | 08:11 AM
zomart's Avatar
what size tires are you running? a larger tire circumference than stock will make the speedometer read slower than you're actually travelling.
Modified by zomart at 2:20 PM 6/3/2004
Old Jun 3, 2004 | 05:49 PM
Default Re: What is the rpm when driving 60 mph???? (zomart)
update- my car's RPM is only @ 3500 @ 80 mph. i checked today and noticed ha.
Old Jun 3, 2004 | 11:40 PM
leechungsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zomart &raquo;</TD></TR><TR><TD CLASS="quote">what size tires are you running? a larger tire circumference than stock will make the speedometer read slower than you're actually travelling.
Modified by zomart at 2:20 PM 6/3/2004</TD></TR></TABLE>
That's would be my guess as well.
Old Jun 4, 2004 | 06:59 AM
Smeeg Heed's Avatar
Default Re: What is the rpm when driving 60 mph???? (Lee Chun)
unless the speedo was adjusted when the different tires were put on then that wouldn't affect apparent speed vs the RPMs. Would still be the same.
Old Jun 4, 2004 | 07:19 AM
zomart's Avatar
Default Re: What is the rpm when driving 60 mph???? (Smeeg Heed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smeeg Heed &raquo;</TD></TR><TR><TD CLASS="quote">unless the speedo was adjusted when the different tires were put on then that wouldn't affect apparent speed vs the RPMs. Would still be the same.</TD></TR></TABLE>
yes, but read his other question. his post before mine asked why his speedo showed 55 when he was going 65.
Old Jun 4, 2004 | 09:33 AM
Lawteg92b's Avatar
Sounds about right, depends though, what gear are you into around 60mph?
Old Jun 4, 2004 | 09:44 AM
mrmonk's Avatar
Default Re: What is the rpm when driving 60 mph???? (96integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96integra &raquo;</TD></TR><TR><TD CLASS="quote">at eighty im at like 3800...i'm not doing 45k's until im at 100mph</TD></TR></TABLE>
Affirmative
Old Jun 4, 2004 | 09:57 AM
..::91TEG-G2::..'s Avatar
Default Re: What is the rpm when driving 60 mph???? (mrmonk)
i have a G2 ls auto too.. i got some questions bout this also..
lets say you drive at 65mph rpms for me are at between 2900-3200 rpms.. (not sure if thats normal, you tell me) do you use more gas by being at higher RPMs? and is it bad for your engine to be running at those high of rpms for a period of time?
Old Jun 4, 2004 | 10:17 AM
JFG Kevin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AznJohn33 &raquo;</TD></TR><TR><TD CLASS="quote">yessss somebody's 1st post doesn't suck.
Mine's at 4k at 80mph, but we drive completely different cars. Eh. </TD></TR></TABLE>
i'm with you...
Old Jun 4, 2004 | 11:01 AM
eric8876's Avatar
Default Re: What is the rpm when driving 60 mph???? (aznstyler119)
mines below 4k at 80 but i have an auto
Old Jun 4, 2004 | 04:15 PM
Gerbilo's Avatar
Default Re: What is the rpm when driving 60 mph???? (eric8876)
3k @ 60, 4k @ 80.
00 B18C1 w/ 5sp
houston integra
May 21, 2007 06:39 AM
mac10311
Jan 8, 2007 08:22 PM
honDA_b18
Jul 16, 2006 11:39 PM
2ndgentegracer
May 21, 2005 06:48 AM
drussell4801
Apr 7, 2005 12:36 AM
