cylinder compression low!!
Old Jun 2, 2004 | 09:03 PM
92siracer's Avatar
Default cylinder compression low!!
i did a compression test on a friends 95 gsr motor and the numbers were
#1-130...#2-130...#3-125...#4-130
why are they soo low?? arent they supposed to be like 180+? And what can he do to fix?
Old Jun 2, 2004 | 09:07 PM
Darkane's Avatar
Default Re: cylinder compression low!! (92siracer)
Did u do it with the throttle wide open? My ls was 120 until i opened the throttle and it was 170ish. hope that helps.
Old Jun 2, 2004 | 09:30 PM
92siracer's Avatar
Default Re: cylinder compression low!! (Darkane)
oh shiet nah we didnt do the test at WOT...ill re-do it tomorrow and see what the numbers are...thanks
Old Jun 2, 2004 | 09:38 PM
Darkane's Avatar
No prob happy to help, one more quick thing. If your results are still dissapointing try pouring some motor oil in the cilinder through the plug hole, like 50ml or so then do the test again at WOT and that should give you the max Compression. then u can see If theres anything wrong with your rings too. Good luck.
Old Jun 2, 2004 | 10:29 PM
91DAveLS's Avatar
You test your compression with the throttle wied open?!?
umair
Dec 7, 2009 10:37 AM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
gs-R_swap
Oct 4, 2009 12:12 PM
climb_on
Jul 29, 2007 03:40 PM
GODSPEED33
Dec 22, 2006 06:04 AM
