do i need a new pressure plate or bushings?
Old Jun 2, 2004 | 08:13 PM
dFreezy's Avatar
Default do i need a new pressure plate or bushings?
after my last clutch cable snapped, i installed a new one, but adjusting it can't fix how hard shifting is. most of the time it is difficult to shift into gear (reverse makes an awful grinding noise too)- it kind of resists, and then i have to use some force to get it into gear. 4th and 5th are easier to shift into than the others. at random times, the shifting is normal and smooth...when the car is off, the car can shift smoothly in between all gears. at first i was thinking i needed a new clutch, but from searches on h-t it sounds like maybe its the pressure plate or new bushings that i need. any ideas?
for being a n00b
Old Jun 2, 2004 | 09:28 PM
4DRmafia's Avatar
u either need to refill ur tranny fluid
Old Jun 3, 2004 | 04:00 AM
dFreezy's Avatar
Default Re: (civicsidude91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsidude91 &raquo;</TD></TR><TR><TD CLASS="quote">u either need to refill ur tranny fluid </TD></TR></TABLE>
i actually forgot to mention i did this about 2 weeks ago using honda MTF. made a damn mess, but i did it...
Old Jun 3, 2004 | 07:22 AM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
welcome to the 'i made a mess in the garage with tranny fluid' club! i'm a member, too!
Old Jun 3, 2004 | 07:26 AM
speed_racer012's Avatar
Default Re: (MugenDude)
hey me to!
did you check your throw out bearing?
Old Jun 3, 2004 | 09:24 AM
dFreezy's Avatar
Default Re: (speed_racer012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speed_racer012 &raquo;</TD></TR><TR><TD CLASS="quote">hey me to!
did you check your throw out bearing?</TD></TR></TABLE>
no, i havent had a chance to look underneath yet, since i dont have jackstands here at school...i also read somewhere that someone had their release arm spring pop off, i guess i'll look at that too. has anyone had that happen?
Old Jun 3, 2004 | 10:06 AM
Default Re: (bl@sterVT)
yeah the spring on mine is bent so I don't think it throws out all the way, I go threw clutches like crazy. probably need to smooth off my flywheel to but it's not worth it right now
Old Jun 3, 2004 | 11:24 AM
keithv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bl@sterVT &raquo;</TD></TR><TR><TD CLASS="quote">
i actually forgot to mention i did this about 2 weeks ago using honda MTF. made a damn mess, but i did it...</TD></TR></TABLE>
An easy way to fill your tranny is to get a fluid pump. This one works great.
http://doityourself.com/store/6847610.htm
I got mine at a local NAPA Parts store.
Old Jun 3, 2004 | 12:47 PM
dFreezy's Avatar
Default Re: (keithv)
i ended up using something like this thing below (worst mistake ever), but couldnt get it to pump smoothly...i ended up just using a funnel and a long hose adding the mtf slowly...worked much better
MilFhunter001
Jul 21, 2006 07:17 AM
JFG Kevin
May 7, 2006 12:12 PM
The Stance
11
Aug 6, 2005 04:05 PM
$$broke_db8
May 22, 2005 05:10 PM
JDMlyfestyle
Sep 24, 2004 12:04 PM
