Problems installing JDM front end w/ OEM HID w/ A/C
Old Jun 2, 2004 | 08:12 PM
Pikey's Avatar
Default Problems installing JDM front end w/ OEM HID w/ A/C
I have a 1997 ITR with factory A/C and recently purchased a JDM front end along with the OEM HID headlights. The bodyshop that is currrently installing the front end told me the A/C will be an issue due to the 2 lines to my receiver drier being in the way of the ballast that is connected to the HID lights. The bodyshop recommeds removing these 2 lines, any way around this so I am able to retain my full A/C system ?
Old Jun 2, 2004 | 10:03 PM
:jdmshmaydm:'s Avatar
Default Re: Problems installing JDM front end w/ OEM HID w/ A/C (Pikey)
You can bend them out of the way, just be cautious. It'll work.
Old Jun 3, 2004 | 04:46 PM
DragII's Avatar
25 Year Member
Default Re: Problems installing JDM front end w/ OEM HID w/ A/C (Gatecrasher20AF)
yup, you just bend them out of the way, it's really easy, and doesn't hurt anything.
Old Jun 3, 2004 | 07:08 PM
NWP4LIFE's Avatar
You would think a body shop would be smart enough to figure out that all you need to do is the bend the lines just a little bit oh well, just listen to our advice and leave your A/C intact.
Old Jun 3, 2004 | 10:08 PM
mikehonda's Avatar
All I did was bend the A/C service port down. Fitment was perfect after that. Also, JDM A/C line that runs in the same place is a slightly diffrent shape and has the service port relocated to clear the ballast.
mikehonda: who got the JDM pipe and never put in in
Old Jun 3, 2004 | 10:25 PM
NWP4LIFE's Avatar
Default Re: Problems installing JDM front end w/ OEM HID w/ A/C (mikehonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikehonda &raquo;</TD></TR><TR><TD CLASS="quote">mikehonda: who got the JDM pipe and never put in in </TD></TR></TABLE>
that's hardcore jdm whorage right there
Old Jun 4, 2004 | 07:42 AM
Pikey's Avatar
Thanks for all the advice guys. The bodyshop decided to not take the chance of bending the lines and was able to custom make some new lines that are routed out of the way of the ballast.
Old Jun 4, 2004 | 08:44 AM
DragII's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pikey &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for all the advice guys. The bodyshop decided to not take the chance of bending the lines and was able to custom make some new lines that are routed out of the way of the ballast.</TD></TR></TABLE>
I hope they did it cheap because it literally takes 1 minute do this.
Da92_1
May 3, 2006 01:21 PM
eboixing
Feb 26, 2005 10:14 AM
GuruFury
Feb 7, 2005 09:48 PM
Stryker
Nov 14, 2002 12:43 AM
TypeR1558
May 23, 2002 09:43 PM
