Where is teh transmission fill bolt?
There should be a yellow dipstick in the tranny towards the firewall. Its kind of low. There is no fill bolt, you put fluid in the same place you check the fluid level. Hope this helps
the dipstick is to the top/back of the tranny. should have a yellow handle. do you have the oem intake system on there still where you can't see it? if you've got an aftermarket intake, you should be able to see it plain as day.
ocdcivic
Dec 11, 2004 10:11 AM
2lobes1engine
26
Jun 29, 2004 08:27 PM
