no power in vtec?
Old Jun 2, 2004 | 03:04 PM
Inextricabledrvr's Avatar
Default no power in vtec?
just replaced flexpipe and when i drove off from the muffler shop, it felt like there was no power in vtec. What could be the problem?
any input would be great...
97SH
Apexi World Sport
aem short ram
aem pullies
dc header (POS)
carsound high flow cat
FPR @39PSI
Dyno #'s 163.6 HP 134.5 TQ (terrible weather conditions)
95 degrees outside and easily over 100 in the dynoroom.
Modified by Inextricabledrvr at 4:28 PM 6/2/2004
Old Jun 2, 2004 | 03:08 PM
Kal's Avatar
Kal
Default Re: no power in vtec? (Inextricabledrvr)
they might have damaged the o2 sensor.
Old Jun 2, 2004 | 03:11 PM
Default Re: no power in vtec? (Kal)
how would you know if it was damaged?
the CEl would have came on correct?
Modified by Inextricabledrvr at 4:27 PM 6/2/2004
Old Jun 2, 2004 | 08:48 PM
caLiH22A's Avatar
Even though a CEL does not appear for a bad O2 sensor, the sensor can still be damaged and it can be sending bad information to the ECU causing the motor to run poorly.
Old Jun 2, 2004 | 09:54 PM
Default Re: no power in vtec? (caLiH22A)
how does an O2 sensor get damaged ?
sprayed with somethin over it?? i.e chemicals?...etc...
how much does an O2 sensor cost to fix ?
man this would suck if that guy damaged my O2 sensor. I hope it isnt expensive to fix.
thanks guys
Old Jun 2, 2004 | 10:00 PM
drewwatts23's Avatar
i had the exact same problem with mine. I replaced my o2 censor thinking that was the problem, but it remaned the same. I then checked my fuel pump and figured out that it was bad. I replaced it and it ran fine.
You may want to just take a look at it.
Old Jun 2, 2004 | 10:06 PM
Default Re: no power in vtec? (drewwatts23)
how can you tell if a fuel pump is bad or not?
Old Jun 2, 2004 | 10:11 PM
Well if your car is cutting in and out while your driving and just running on low end then that is a sign of a bad fuel pump. You cant really check it unless you take it into a shop to electronically test it on a computer.
Old Jun 2, 2004 | 10:19 PM
how much did they charge you for the fuel pump?
Old Jun 2, 2004 | 10:25 PM
its like a couple hundred dollars. a 02 senser is about 60-70 dollars. 02 sensers are really easy to replace though. They are by the cadillac converter and you just take the old one out and plug in the new one. Just to let you know.
Old Jun 2, 2004 | 10:27 PM
thanks drew,
you have been very helpful
boosted civi
Mar 10, 2009 07:15 PM
Tom123456
Jul 28, 2006 12:04 AM
Amused
May 9, 2006 06:59 AM
bgoetz
Jun 8, 2005 07:50 AM
vteckiller
Jul 23, 2003 09:51 AM
