Finally got pics of new DART motor!
well got the motor in and running got about 500 miles on it so far but here is one of the pics
the setup is a
Dart 2.0 84.5 11.7.1
ported polished head
89mm crank
oilver rods
oh yea on skunk stage 1 cams on a mustang dyno
Modified by snake01 at 10:14 PM 6/23/2004
Modified by snake01 at 10:25 PM 6/23/2004
the setup is a
89mm crank
oilver rods
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg »</TD></TR><TR><TD CLASS="quote">arent those not allowed in street class. that sucks. but its a nice block otherwise</TD></TR></TABLE>
Dart blocks come deckplate or stock deck.
Stock deck height is fine.
Street class = no deck plates is the only restriction I see, not all "dart blocks"... is it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AM Specified 39 »</TD></TR><TR><TD CLASS="quote">
Street class = no deck plates is the only restriction I see, not all "dart blocks"... is it? </TD></TR></TABLE>
I believe the rules is only OEM blocks. since DART is not OEM you can't use a DART.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by qi_doy »</TD></TR><TR><TD CLASS="quote">
I believe the rules is only OEM blocks. since DART is not OEM you can't use a DART.</TD></TR></TABLE>
Ndra allows them.
<<<<<-----Dart inside
Ndra allows them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snake01 »</TD></TR><TR><TD CLASS="quote">here's the setup
dart 2.0 block
weisco 84.5 pistons 11.8.1
ported and polished head
oliver rods
89mm eagle crank
skunk stage 1's just for now
hytech 2.0 header</TD></TR></TABLE>
Very nice, The Skunks Stage 1's will Actually Be a Fine choice!
Eric
dart 2.0 block
oliver rods
89mm eagle crank
Eric
dart 2.0 block
oliver rods
89mm eagle crank
looks and sounds good.
i have set of the RS machine vtec cams that i think will run
way better. let me know.
dart 2.0 block
oliver rods
89mm eagle crank
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGbrknuoff »</TD></TR><TR><TD CLASS="quote">Dart blocks come deckplate or stock deck. </TD></TR></TABLE>
All Dart blocks are closed deck. NDRA and IDRC both allow them, along with our cylinder head.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Moxie »</TD></TR><TR><TD CLASS="quote">
All Dart blocks are closed deck. NDRA and IDRC both allow them, along with our cylinder head.</TD></TR></TABLE>
They don't allow the "Deckplate" ones though.
Only the stock deck height.
I think that is reffering to the deck height.
