95 gsr tps sensor?
Old Jun 2, 2004 | 12:22 PM
ubreak_ubuy's Avatar
Default 95 gsr tps sensor?
Hi does anyone know if the TPS sensor on the 94 LS will work on a 95 GSR throttle body? i know the map sensor is the same but not sure about the tps. anyones help is greatly appreciated
Old Jun 2, 2004 | 03:22 PM
Kendall's Avatar
It will indeed work, just be sure to properly calibrate it.
Old Jun 2, 2004 | 03:31 PM
Lord Helmet's Avatar
Default Re: (Kendall)
yes all b-series 94+ dohc teg and 92+ civics are interchangable. just calibrate it after you install it.
Old Jun 2, 2004 | 04:20 PM
Default Re: (sleeperciv)
thanks guys for your help. but how exactly do you calibrate it?
Old Jun 2, 2004 | 04:38 PM
Default Re: (raceinspired)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raceinspired &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys for your help. but how exactly do you calibrate it? </TD></TR></TABLE>
measure voltage readings at the yellow/blue(+) and green/blue(-) wire. it should read 0.5 V at full close throttle and 5 V at full open throttle. there should be a smooth transition as the throttle is depressed.
btw ignition should be on (common sense here)
Old Jun 2, 2004 | 04:39 PM
rev2ninetyper's Avatar
im wondering the same thing, i might have to change mine out.
Old Mar 1, 2005 | 12:44 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">yes all b-series 94+ dohc teg and 92+ civics are interchangable. just calibrate it after you install it.</TD></TR></TABLE>
would a 90-93 ls tps work on a 95 ls?
motrayEG6
Oct 21, 2011 02:00 PM
perseverance
Dec 22, 2006 09:08 PM
rwcdrums
Aug 15, 2004 05:31 AM
integraver
Nov 3, 2003 04:30 AM
