EF Aftermarket Injector question
Old Jun 2, 2004 | 11:46 AM
soulstream's Avatar
Default EF Aftermarket Injector question
I know when you add Prelude OBD-1 injectors to an EG, you have to add and wire a resistor box. The question is, if you have RC OBD-1 injectors (self resisted) and put them in an EF, do you just remove the resister box and change the injector plugs?
Old Jun 2, 2004 | 11:48 AM
APEX CRX's Avatar
Default Re: EF Aftermarket Injector question (soulstream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soulstream &raquo;</TD></TR><TR><TD CLASS="quote">I know when you add Prelude OBD-1 injectors to an EG, you have to add and wire a resistor box. The question is, if you have regular OBD-1 injectors (self resisted) and put them in an EF, do you just remove the resister box and change the injector plugs?</TD></TR></TABLE>
yes, remove the resistor box and solder all the wires together. OBD-1 clips are different so either modify your clips with a small dremel bit to remove the center tab inside the clip or solder on OBD-1 clips
Old Jun 2, 2004 | 11:49 AM
soulstream's Avatar
ok thats what i figured.. great thanks
accordin 2 me
Dec 12, 2011 05:05 PM
beansandrice
33
Sep 8, 2009 04:18 PM
beansandrice
Aug 28, 2009 07:32 PM
Hondamonster
Jul 29, 2007 08:42 PM
nevin
Aug 16, 2005 03:21 PM
