cam seal replacement question
Old Jun 2, 2004 | 10:28 AM
StupidSlowRSX's Avatar
Default cam seal replacement question
I was pulling my cam gears off and I noticed there are seals there as well. If I order cam seals from honda will I get seals for the dizzy and cyl sensor as well?
Old Jun 2, 2004 | 10:30 AM
Keebler's Avatar
Default Re: cam seal replacement question (StupidSlowCRX)
Probably not. Everything is separate when you do it like that. Try a FelPro gasket set where you get the valve cover, cam seals, dizzy and all that in one... When you are in there you will want to change it all, unless you need to just do the cam seals.
TheWalrus
Jan 30, 2006 05:47 AM
DAintegraGSR
May 21, 2005 06:06 PM
urgonnalearn2
Nov 4, 2004 08:45 AM
StatGSR
Jun 6, 2004 07:38 PM
