95 gsr in 97 hatch wiring woes
official honda whore
well my friend tried doing his own swap, he used his own harness and spliced in the dizzy, alternator and fuel injector plugs....... it wouldnt run right, so now he hired me to do the rest, if i explain the setup will someone tell me what wiring will need to be done
95 gsr motor
97 ek hatch
he just bought 97 ex harness
jdm **** jumper
95 obd1 ecu
i know how to splice alternator, dizzy and injectors, i just dont know about everything else, i searched and found some things like iacv etc and with the ex harness vtec should be a plug and play right, please let me know, any help is appreciated
and yes i did search
sometimes on dial up posting is alot faster
95 gsr motor
97 ek hatch
jdm **** jumper
95 obd1 ecu
woah woah woah.. i have a 94 gsr in my 99, and i never had to do any splicing....
just use your original harness ( cx, dx, whatever ) and plug that onto what ever you can of the original sensors on the GSR engine. Then run more wires from the sensors that arent' on the harness right to the ECU. Then get an adapter harness for the OBD I ecu and you are set.
You don't need your 97 ex harness...
I also reused my DX fuel rail and injectors; THEN you dont' have to rewire anything. They are OBD II so they will plug right into your original harness. AND since they are the same flow rate as the GSR ones, they will work fine ( 240cc i believe )
try to use the 97 ex ecu to start the gsr, dont worry about the obd2 to obd1 conversion harness until it gets running. check the check engine light codes, and post what your getting..
you could use the 97 ex harness. but I would just re-wire the 97 dx harness
need to have the codes before you can find out whats wrong with it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockCRX »</TD></TR><TR><TD CLASS="quote">try to use the 97 ex ecu to start the gsr, dont worry about the obd2 to obd1 conversion harness until it gets running. check the check engine light codes, and post what your getting.. </TD></TR></TABLE>
I disagree with that. use the adapter harness, and if you do get codes, it will be less then what you would have if you didn't use it. Because you're GOING to get codes if you use the OBD II ecu on the OBD I engine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BigBlockCRX »</TD></TR><TR><TD CLASS="quote">you could use the 97 ex harness. but I would just re-wire the 97 dx harness</TD></TR></TABLE>
Yeah, you could use that, but I think all you gain is the extra wire for vtec if I'm thinking right.
Hanmin
Oct 1, 2010 11:33 PM
Unphzd
18
Aug 24, 2010 07:25 PM
RC_Benjamin
Mar 14, 2006 05:44 PM
vtec25
Oct 9, 2005 05:49 PM
