ECU swap question
I have an '89 crx si and im going to be swapping the stock d16 to a dohc zc. I'm going to have to put in an '89 integra ECU(PG7 i think). Will it be alot of wire configuring to swap this ECU in? I called a shop and he said it's a whole bunch more wires to alot more sensors etc. Is this going to be a tedious job or a simple swap? Thanks
Plugs right in...you will have to change 2 wires for the cam angle sensor if you have an Si...ir if your car is DPFI then you'll have to wire it for MPFI...there are lots of great writeups in the FAQ of this forum.
If you have an Si you can run the ZC with that ECU (PM6)...but it will probably run better with the PG7 or the ellusive PM7.
i was going to order a zc dohc swap for my crx 89 si will the si ecu work? and is there and thing el
h22_crx
Aug 16, 2005 07:31 AM
DarknessInside51
May 31, 2004 04:20 PM
