do I need "heavy duty" rear hatch supports/lifts?
Old Jun 2, 2004 | 08:25 AM
CrazyModGSR's Avatar
Default do I need "heavy duty" rear hatch supports/lifts?
I'm sure I'll get a lot of BS on this post about my wing being to big, but I guess I'll ask anyway. The rear hatch supports/lifts on my '94 teg are crap, so I bought another used set from a '97 Integra off ebay. I just installed them, and they are a little better, but still will not keep the trunk open. Do I need to buy some special heavy duty lifts? If so, where can I find them?
Thanks
Old Jun 2, 2004 | 08:27 AM
Googs16's Avatar
Default Re: do I need "heavy duty" rear hatch supports/lifts? (CrazyModGSR)
Acura sells stronger shocks for stock wings
Old Jun 2, 2004 | 08:32 AM
Default Re: do I need "heavy duty" rear hatch supports/lifts? (Googs16)
you know where i can get them for fairly cheap?
Old Jun 2, 2004 | 09:29 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Googs16 &raquo;</TD></TR><TR><TD CLASS="quote">
Acura sells stronger shocks for stock wings</TD></TR></TABLE>
They're different? No wonder my hatch is so hard to close w/o the wing on.... it's wierd, cuz the stock wing isn't all that heavy.
Old Jun 2, 2004 | 09:34 AM
Default Re: do I need "heavy duty" rear hatch supports/lifts? (PatrickGSR94)
well, i called the stealership and they told me $75 EACH for the hatch support struts but who knows if they will even hold - i need to find other 'teg owners w/ the Kaminari wing to see what they have for a rear hatch strut
Old Jun 2, 2004 | 09:41 AM
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CrazyModGSR &raquo;</TD></TR><TR><TD CLASS="quote">well, i called the stealership and they told me $75 EACH for the hatch support struts but who knows if they will even hold - i need to find other 'teg owners w/ the Kaminari wing to see what they have for a rear hatch strut</TD></TR></TABLE>
Check out auto parts stores, I know AutoZone carries a large assortment of hood and trunk supports, specifically made for different applications.
The supports you got of ebay must have been from a car w/o a wing, because the part numbers are indeed different. Carland Acura sells the GS-R supports for $52 each, or try an auto parts store.
Old Jun 2, 2004 | 09:45 AM
JFG Kevin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">
They're different? No wonder my hatch is so hard to close w/o the wing on.... it's wierd, cuz the stock wing isn't all that heavy.</TD></TR></TABLE>...
um sir...it's pretty heavy...haha...well at least to me...too much for the original shocks...but then again...i have a sedan...no shocks...
Old Jun 2, 2004 | 09:48 AM
Community Builder
Default Re: do I need "heavy duty" rear hatch supports/lifts? (aznstyler119)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznstyler119 &raquo;</TD></TR><TR><TD CLASS="quote">...
um sir...it's pretty heavy...haha...well at least to me...too much for the original shocks...but then again...i have a sedan...no shocks...</TD></TR></TABLE>
wing is sitting in my attic, I was moving it around just the other day, it's not heavy (5 lbs at most maybe).
Old Jun 2, 2004 | 09:51 AM
ThePro's Avatar
The ITR wing from Acura comes with new hatch supports. I bought the wing without the hatch supports and it won't open on it's own anymore. You can stop halfway and the hatch will sit there. So they actually are a little stronger. How much stronger? I dunno..
Old Jun 2, 2004 | 09:55 AM
Default Re: (ThePro)
it's not a stock wing. it's a Kaminar wing. I don't know how much the wing itself weighs, but the hatch is heavy as hell to lift w/ the bad supports. I just called auto zone and they said $40 ea. for stock supports,
Old Jun 2, 2004 | 10:08 AM
spoonfed95's Avatar
Default Re: (CrazyModGSR)
Easy fix.... Rip that wing off your car, problem solved. No I'm just kidding, I would use new OEM Supports (Wing Type) for the rear. I think the used supports you bought were worn out or at least getting there. Probably why there on eBay.
Old Jun 4, 2004 | 09:49 AM
JFG Kevin's Avatar
wing is sitting in my attic, I was moving it around just the other day, it's not heavy (5 lbs at most maybe).</TD></TR></TABLE>
i'm not sayin its heavy for itself but it's heavy for the shock..doode..i must be hella weak if i think that is heavy....i have a wing west stock spoiler
91tegra07
Apr 17, 2008 09:34 PM
icuracing.com
Dec 22, 2005 03:30 PM
SOmbody
Jun 6, 2004 08:48 PM
CrazyModGSR
Jun 2, 2004 10:11 AM
92HB_HB
Nov 9, 2003 11:23 AM
