too much pressure?Please Help
i went up to the gas station today to put pressure in my tires. after i filled them up i wanted to head home. But i had a hella of time doing it. i had a hard time steering the thing. when i did get home i check the tires. The back tire was a hard as a rock while the front lost pressure. The steer was pushing to the right. is that what is causing this?
hard steering is low pressure most likely. What did you fill them up to? What was the end pressure? Sounds like either a slow leak or a loose nut behind the bars. Low pressure up front will make the bars want to turn themselves.
DSC240sx
Mar 9, 2003 01:45 PM
