01 F4i idle problems
Old Jun 2, 2004 | 06:39 AM
derxz's Avatar
Default 01 F4i starting problems
My bike has around 9000 miles on it; after 2 long trips this past week I came home, went for a short ride to a friends, come back and the bike doesn't want to start. Now i have to hold the throttle in while starting it. When it does start, it idles at most 1k rpms. Before this problem the warmup period idled at 3k. Once my bike is warmed up to operating temp, it runs fine. Any ideas or suggestions? Thanks, Derek
**UPDATE**
That was the case, I've replaced the plugs, cleaned the air filter. I've not put the air filter back on, but the bike will not start now. It just sits and tries to start. Nothing happens. I've checked and I get spark from the plugs. Any ideas? thanks, Derek
Modified by derxz at 2:10 AM 6/4/2004
Old Jun 2, 2004 | 07:39 AM
tonydatyga's Avatar
Default Re: 01 F4i idle problems (derxz)
Check battery voltage, running voltage and if that checks out... replace ecu with known good unit. I hate "subsitute w/ known good part" but its the fastest way
Old Jun 2, 2004 | 09:48 AM
ScubaStevo80's Avatar
Default Re: 01 F4i idle problems (tonydatyga)
First thing I would check is your idle adjustment screw... if its not that, check the obvious... air filter, injectors, battery, ecu... etc.
Old Jun 2, 2004 | 12:05 PM
slylos's Avatar
Does your "FI" light stay on while its warming up? Or flash?
Old Jun 2, 2004 | 12:16 PM
derxz's Avatar
Default Re: 01 F4i idle problems (slylos)
update: i pulled it all apart. the plugs were pretty bad, replaced those. also the air filter was really dirty. I'm cleaning that right now.
Modified by derxz at 4:02 PM 6/3/2004
Old Jun 3, 2004 | 05:12 PM
derxz's Avatar
**UPDATE**
Old Jun 3, 2004 | 09:33 PM
slylos's Avatar
Are you getting fuel??
.Kevin.
Honda Motorcycles
Aug 18, 2007 06:27 PM
tek_civic
Honda Motorcycles
Sep 18, 2006 10:46 AM
onecajun
Honda Motorcycles
10
Jul 20, 2006 05:45 PM
torr
Honda Motorcycles
May 22, 2005 12:46 PM
Newkdog
Honda Motorcycles
10
Jul 5, 2004 05:54 PM
