vtec water/oil pump?
Old Jun 2, 2004 | 06:27 AM
Phatch99's Avatar
Default vtec water/oil pump?
is a vtec water and oil pump a must for lsvtec?
Old Jun 2, 2004 | 08:12 AM
dfoxengr's Avatar
Default Re: vtec water/oil pump? (Phatch99)
nope. all oil pumps are the same. and you just need to match the h2o pump with whatever timing belt ou use. ie. ls pump=ls belt.
Old Jun 2, 2004 | 08:16 AM
arw321's Avatar
Default Re: vtec water/oil pump? (hybridvteceg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridvteceg &raquo;</TD></TR><TR><TD CLASS="quote">nope. all oil pumps are the same. and you just need to match the h2o pump with whatever timing belt ou use. ie. ls pump=ls belt.</TD></TR></TABLE>
All newer b series pumps are the same. I believe 97 or 98 and up. The difference between the older non vtec vs. vtec pumps are the pressure relief spring. The vtec spring is stiffer, and will therefore bypass oil at a higher pressure compared to the non vtec spring.
Use a vtec oil pump and a vtec water pump for an ls/vtec.
Old Jun 2, 2004 | 08:17 AM
dfoxengr's Avatar
Default Re: vtec water/oil pump? (arw321)
98 and up
Old Jun 2, 2004 | 11:13 AM
Phatch99's Avatar
so if it's a 94 ls than i would need to switch and get any b series 98+ pumps?
Old Jun 19, 2004 | 09:15 PM
96MidoriHatch's Avatar
i thought even the newer pumps were different as far as the pressure relief spring in the vtec to non vtec
Old Jun 19, 2004 | 09:16 PM
dfoxengr's Avatar
no just that all 98+ integra pumps are the same.
Old Jun 19, 2004 | 11:18 PM
jamessh1's Avatar
i just bought a vtec oil pump for my 99' ls soon to be ls/vtec. I've never heard this info b4 about the vtec pumps being the same for 98+.....................
Old Jun 20, 2004 | 05:31 AM
dfoxengr's Avatar
Default Re: vtec water/oil pump? (jamessh1)
do as much reading as i do and then you will.
Old Jun 20, 2004 | 12:44 PM
jamessh1's Avatar
i just checked the acuraparts247.com and sure enough the oil pump is exactly the same (at least same part #) for 99 ls tegs and 99 gsr tegs . I spent $55 CDN on something i don't need, but thankfully my girlfriend's brother is doing the same swap with me but his car is a 94 so he can buy it off me.
stevenDAtegra
Dec 15, 2008 07:53 AM
bens_redeg
Jul 10, 2004 07:11 AM
Tinker219
May 5, 2003 08:22 AM
teg92
Dec 6, 2002 06:20 PM
3rdGteg
Nov 3, 2002 11:08 AM
