----- JDm B16A 1st Generation (89-91 SI-R) complete Swaps -----
Looking for a complete JDM B16A 1st Generation (89-91 Honda Civic SI-R) engine changover? I'll hook you up...
90-91 Si-R (B16A 1st Generation)
DOHC VTEC 4 Cylinder 16 Valve
• Transmission: Cable
• Diplacement: 1595cc
• Redline: 8200 rpm
• Compression Ratio: 10.4:1
• HP: 160hp@7600
• Torque: 111 lb-ft@7000
• Equipped w/ PWO or PR3 ECU
Price: $1350.00 USD
The Engine Swap includes the following:
Complete Motor
-Block
-Intake Manifold
-Complete Head
-All Sensors
-Exhaust Manifold
-Fuel Rail
-Injectors
-Throttle Body
-Alternator
-Starter
-Ignition Wires
-A/C Compressor
-Power Steering Pump
PR3 ECU(Computer)
Y1 Cable Transmission
- with Clutch components assembled to the engine(5 speed Transmision)
Axels, Factory Stock OEM Engine Mounts and Engine Wiring Harness(Cut from the car, not from the engine)
*All engines are JDM(Japan Domestic Market). 3 month warranty provided. A tracking number and papers for engine are provided.
*Located in Eastern Canada. Will ship anywhere in the USA + Canada. Between $250-$400 shipping depending where you are located. Check out web page for pictures and prices!!! I have many in stock!!!
*Email: jspec_engines@canada.com
*Web Site: http://www.jspecengines.8m.com/home1.html
If you have any questions please email me, I will be happy to help you out.
Thanks
• Redline: 8200 rpm
• HP: 160hp@7600
Price: $1350.00 USD
Complete Motor
-Block
-Intake Manifold
-Complete Head
-All Sensors
-Exhaust Manifold
-Fuel Rail
-Injectors
-Throttle Body
-Alternator
-Starter
-Ignition Wires
-A/C Compressor
PR3 ECU(Computer)
Thanks
apparenlty you can get the swap installed into a ED/EF with new timing belt/water pump, gaskets, tune up, etc for 1900 US in toronto...
