pcv valve (smoke)
Wut up everyone. Well i just finished putting my motor back together last night and i'm getting smoke out of the pcv valve and light smoke out the exhaust (it was dark outside so i couldn't tell what color the smoke was coming out the exhaust). i had to the replace the pistons and get new rings. i melted one piston and the on the other piston the side of it cracked. and when this happened i was smoking bad. out the pcv and the exhaust. so i know that when i did this i got alot of oil in my exhaust. could it be burning off and going out the exhaust? can the smoke coming out the pcv valve be coming out be cause my rings aren't broken in yet? someone help...i decided to rebuild the head also. found out i had 3 bent valves. i listed my set-up below. HELP!!
99 gsr
stock block (new pistons, new rings)
stock head (rebuilt)
drag gen III turbo kit
t04e turbo (rebuilt)
msd
vafc
99 gsr
msd
vafc
My car smoked for a couple of hours after the rebuild. Oil was in the cat and muffler and it took a while for it to burn off. My mech. basically let it run for 2 hours until it went away.
ksuggs8503
15
Oct 23, 2008 01:28 PM
Jreycrx
May 19, 2007 09:31 AM
