Altenator question.
Old Jun 1, 2004 | 11:36 PM
nautica_t's Avatar
Default Altenator question.
okay my alternator has gone wack, i have to hit it so that it charges my battery. so i'm going to replace it.
question is what should i replace the alternator with.
i have a 1st gen b16. i'm thinking of either getting an OEM one, but for what model engine would work, perhaps the Si/SiR (canadian) b16 altenator, or would that not work. or getting a higher amperage altenator.
-> i currently have the black housing projectors installed, and the bulbs they use are H1's both low and high beams. i'm also running an audio system as well. with 2 12's. so my question is, should i get a higher amperage one, if so what kind should i get or should i stick with the oem one from a Si/SiR
TIA..
Old Jun 2, 2004 | 12:18 AM
civickiller's Avatar
Default Re: Altenator question. (nautica_t)
probably the 90-91 teg alternator
Old Jun 2, 2004 | 05:42 AM
nautica_t's Avatar
so i have to get one out of a 90-91 integra.
alright, fitment shouldn't be an issue correct?
this is most important, i need to konw asap....
adn thakns for the reply civickiller, do i need a higher output altenator though?
Old Jun 2, 2004 | 06:18 AM
Cory man's Avatar
The 90-91 teg alternator should be fine. Make sure the pulley size(numbers of ribs) is the same. hth
madman4you
May 18, 2007 08:04 PM
xxxmikenicexxx
Jul 25, 2006 03:10 PM
TurboR1391
Jun 16, 2004 05:19 PM
