Nitrous wiring problem (I hate wiring!)
Old Jun 1, 2004 | 09:35 PM
5spdIntegra's Avatar
Default Nitrous wiring problem (I hate wiring!)
Ok I ran into a problem tonight when I went to use my nitrous tonight. I turned on my bottle heater and it worked for a minute or so then the fuse blew.
Here is how it is set-up: The power is coming from the engine bay fuse box which then goes to a 30 fuse to the toggle switch. I also have tapped into the wire right after the fuse to my nitrous activation switch but the fuse blew before I even touched this.
Could this be a problem with the ground? I admit I don't have the best ground. Will a bad ground blow a fuse? Any help would be great.
Old Jun 1, 2004 | 10:25 PM
Ti3d in's Avatar
Default Re: Nitrous wiring problem (5spdIntegra)
The ground sounds like a good possibility.
Old Jun 5, 2004 | 12:09 PM
Default Re: Nitrous wiring problem (Ti3d in)
bump
nukefivesix
16
Feb 9, 2010 06:51 PM
eg grom
13
Oct 22, 2009 09:44 PM
XRacerX
Sep 9, 2009 08:50 AM
Tippyman
Nov 6, 2006 06:30 PM
drtyhatch
13
Dec 14, 2005 04:43 AM
