question about Gen2 headlights..
hey guys, ima be lowering my car 2 inches and i dont know if i need to re-aim my headlights or not.. i know on the JDM headlights they have those adjusting screws to aim ur headlights up or down, left or right..
my question is this, do i have to re-aim my headlights after this drop to get maximum lighting? and does the usdm 3peice headlights have the adjustment screws?
it's very similar to the jdm ones but i think (don't qotue me on this) that you use a #2 philips screw driver and there are these little black holes in the metal headlight housing frame. You should be able to stick the scredriver down the hole and turn it on this little wheel that has the teeth on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwedBoy2999 »</TD></TR><TR><TD CLASS="quote">it's very similar to the jdm ones but i think (don't qotue me on this) that you use a #2 philips screw driver and there are these little black holes in the metal headlight housing frame. You should be able to stick the scredriver down the hole and turn it on this little wheel that has the teeth on it.</TD></TR></TABLE>
yup, did the same on my old DA.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunkintegra »</TD></TR><TR><TD CLASS="quote">
really? i just checked and i didnt find anything, can i do it while the headlights are still on the car? or do i have to take the headlight housing out and adjust it, sit it back in the car and see how it looks? if anyone has a pic of this, or can get one
</TD></TR></TABLE>really? i just checked and i didnt find anything, can i do it while the headlights are still on the car? or do i have to take the headlight housing out and adjust it, sit it back in the car and see how it looks? if anyone has a pic of this, or can get one
I thin it's safe to say that all headlights are adjustable. To help you though, both USDM and JDM DA headlights definately are adjustable because I've had both and I've adjusted both. You use a philips head screw-driver and just look downward at the lights and you should be able to find the 2 or 3 adjusting screws.
