Ls/vtec Build- Oil Pump
Old Jun 1, 2004 | 08:07 PM
1bar's Avatar
Default Ls/vtec Build- Oil Pump
There are many threads that suggest buying a vtec oil pump when building a ls/vtec motor. But they also say that after 97 or 98 all oil pumps are the same. Both Ls and Gsr oil pumps are product number 9023I have a 98 ls oil pump with around 60k on it. Would it make a difference if i buy one or should i just replace the pressure relief spring with a vtec spring??
Just dont wanna spend 100+ if i dont need too.
thanks
Old Jun 1, 2004 | 08:34 PM
Simple's Avatar
Default Re: Ls/vtec Build- Oil Pump (1bar)
if the numbers match, its the same exact part, springs and all... works that way at the honda dealership i work at.
but to be safe, why not spend the 100 bucks to get a ITR oil pump?
Old Jun 1, 2004 | 08:50 PM
SockEG's Avatar
Default Re: Ls/vtec Build- Oil Pump (Simple)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple &raquo;</TD></TR><TR><TD CLASS="quote">
but to be safe, why not spend the 100 bucks to get a ITR oil pump?</TD></TR></TABLE>
I have to agree... if you are building an LS/VTEC or anymotor for that matter you should buy new oil and water pumps. OEM of course. better to be safe then sorry.
Old Jun 1, 2004 | 08:58 PM
dfoxengr's Avatar
Default Re: Ls/vtec Build- Oil Pump (SockEK)
yeah foo i told you
Old Jun 1, 2004 | 10:08 PM
mmuller's Avatar
Mad Scientist
mm, all 96-up pumps flow and are the same
Old Jun 1, 2004 | 10:34 PM
JDMotive's Avatar
Default Re: Ls/vtec Build- Oil Pump (mmuller)
Yea...a friend of mine works at a local acura dealership.I asked him for an ITR oil pump awhile back and the part # was the same as LS and GSR.You dont really need to replace the oil pump,mainly the water pump.If the oil pump was in working condition before,than it should be ok.
Old Jun 2, 2004 | 05:10 AM
Leader_Racing's Avatar
Default Re: Ls/vtec Build- Oil Pump (JDMotive)
I agree all the pumps are now the same.
Before I would resued the old pump it would be a good idea to pull it apart and look for wear. and while its apart, get your helms out and check the wear on the gears to see if their still within specification.
AB
Old Jun 3, 2004 | 10:25 PM
chrisCNL's Avatar
Default Re: Ls/vtec Build- Oil Pump (abdelsol)
Third that...All the factory oils pumps are the same...if you want more volume get aftermarket if is avalible.
Old Jun 3, 2004 | 10:31 PM
dfoxengr's Avatar
Default Re: Ls/vtec Build- Oil Pump (chrisCNL)
he's not looking for mor vol. just a confirmation on what he thought.
Happyfeat2006
Feb 3, 2009 04:52 PM
civicman69x
Jul 30, 2007 09:04 PM
Jdmb16sir2
Jan 29, 2006 12:43 PM
civcexcoupeblack
Sep 14, 2003 05:38 PM
