flywheel question.
Old Jun 1, 2004 | 07:06 PM
Mr.Death's Avatar
Default flywheel question.
I just purchased a stock flywheel and I'm trying to determine wheather it's 88-89 or 90 91. Does anyone know a way to determine which one I have(number of teeth, diameter of contact area)? Any input would be appreaciated as I'm going to have it lightened and I want to make sure it's the right one. My car is a 90 crx si and the clutch I'm mating the flywheel with is a 90-91 exedy clutch. Thanks.
Old Jun 1, 2004 | 07:35 PM
Mr Furball's Avatar
Default Re: flywheel question. (Mr.Death)
Where did you purchase it from? How do you know it's the right one at all? Stock motor and trans?
Old Jun 1, 2004 | 07:42 PM
crxgator's Avatar
90-91 surface area is 212mm 88-89 is 200mm...
Old Jun 1, 2004 | 07:46 PM
Mr Furball's Avatar
Default Re: flywheel question. (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">90-91 surface area is 212mm 88-89 is 200mm...</TD></TR></TABLE>
Is that from the center out or straight across?
Old Jun 1, 2004 | 09:55 PM
mr. carpenter's Avatar
Default Re: flywheel question. (Mr Furball)
i would think surface area means area and not radius or diameter. might try search seems like i've read this before.
Old Jun 1, 2004 | 10:16 PM
Mr.Death's Avatar
Default Re: flywheel question. (mr. carpenter)
The flywheel I have has a 212 mm contact patch and the clutch I have is also 212mm(exedy 08801b) which leads me to believe that it's a 90-91 flywheel.
CRXSleeper
Nov 10, 2006 10:38 PM
allmotorek8
10
Nov 3, 2005 06:37 PM
Trench_Rat
10
Nov 3, 2005 06:27 PM
Donkey85
Jul 27, 2004 03:24 PM
Downey
Oct 30, 2003 01:32 AM
