rebuilding bottom end
Old Nov 11, 2001 | 05:58 AM
cmdr430's Avatar
Default rebuilding bottom end
question? i am going to build my bottom end this jan. i have spec b's and a bunch of other ****. a guy where i live has some stock bore je pistons and he wants to work out a trade. they are 12.5 cr, will my vafc, and maybe 410 injectors be enough to tune with, or do i need power fc? also is 12.5 going to be to high for pump gas ?
Old Nov 11, 2001 | 09:21 AM
Warren's Avatar
Wrong-Way Wang
Default Re: rebuilding bottom end (cmdr430)
410 is too big. Prelude injectors should be as much as you'll ever need.
Warren
Old Nov 11, 2001 | 11:21 AM
Honda318dx's Avatar
I have a set of 290cc prelude injectors, OBD2.. Will sell them cheap..
Old Nov 12, 2001 | 11:32 AM
RStoR's Avatar
Many people are currently running 12.5 on pump gas. Look at the compression ratio calcualtion listed on this board and determine your actual compression with these pistons. With stock gasket & deck height, you may not be reach a true compression of 12.5 without decking the block.
You will have a fuel issue with that compression! You will probably need to upgrade to 310 injectors at least. Since you are going to depend on the VAFC for fuel tuning, getting a fuel pressure riser and gauge probably won't be a bad idea either. Since you may need to lower static fuel pressure, these will help with that.
Lastly, the biggest concern should be using stock bore pistons. A simple honing may no be enough for proper ring sealing if you have mileage on the engine(25k+). It would suck to do this and then need to pull it apart again because it didn't seal!
dansnyder22
Aug 18, 2009 07:28 PM
Ruben19
Mar 10, 2006 03:23 AM
doublejz
Aug 10, 2005 03:41 PM
GapxGuy
16
Apr 21, 2004 11:33 AM
RTW DC2R
May 24, 2002 06:54 AM
