valve adjustment
Old Jun 1, 2004 | 05:05 PM
slipstreamsi's Avatar
Default valve adjustment
is it required that after you put on new cams, springs, and retainers that you get a valve adjustment?
Old Jun 1, 2004 | 08:43 PM
Whitfield Inc.'s Avatar
Default Re: valve adjustment (slipstreamsi)
Yes I would at least take the time to check them all. I would have to say they will probably be off. What ever cam you choose will ( or should ) have the spec sheet to help you set the lash
Good Luck
Old Jun 1, 2004 | 10:15 PM
Ekasey's Avatar
Default Re: valve adjustment (RageDzine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RageDzine &raquo;</TD></TR><TR><TD CLASS="quote">Yes I would at least take the time to check them all. I would have to say they will probably be off. What ever cam you choose will ( or should ) have the spec sheet to help you set the lash
Good Luck</TD></TR></TABLE> word to that my homie right there
Old Jun 2, 2004 | 07:18 AM
Default Re: valve adjustment (eLusive ek4)
would not getting them adjusted cause my engine to sound really loud and smoke a little, cause thats kinda whats happening. Im going to get a valve spring adjustment today but im just making sure that nothing else could be the problem.
Old Jun 2, 2004 | 07:26 AM
kur0ryu's Avatar
I dont know about smoking a little, but it could definitely cause it to be noisy, depending on the type of noise. loose valve lash will make the engine very clicky.
Old Jun 2, 2004 | 07:27 AM
mmuller's Avatar
Mad Scientist
yeah, you need to adjust them
Old Jun 2, 2004 | 11:29 AM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: valve adjustment (mmuller)
yes valve adjustment is necc. was a valve job done? if so the valves will sit in the seats farther causing the valve lash to slightly loosen. as far as the smoke i would tend to say valve stem seals
Old Jun 2, 2004 | 11:39 AM
7thGear's Avatar
Default Re: valve adjustment (HOOKUPS)
ok i read the civic repair manual
and i sitll dont get it
what kind of tools do u need to adjust valve lash, and how do u physicaly do it? do u just screw the bolt until it touches the valvestem when the valve is in its resting place?
i dun get it
Old Jun 2, 2004 | 11:50 AM
DYNO-PRO
Default Re: valve adjustment (7thGear)
alot of typing 4 this one please give me a call at the shop and i will be happy to explain 909-373-RACE
Old Jun 2, 2004 | 11:54 AM
7thGear's Avatar
haha, i dont think i could take the long distance charge
comeone dude, typing at 70 wpm is a MUST in todays business environment, think of it as an exercise
Old Jun 2, 2004 | 12:03 PM
DYNO-PRO
wow 70 wpm i think im at like 3wpm
Old Jun 2, 2004 | 12:14 PM
7thGear's Avatar
junior high "all the right type" + early teen years spentplaying "starcraft" and later evolving on to "counter strike" = type like a pro
Racewerkz
Jan 26, 2011 07:55 AM
Eyal 951
18
Nov 20, 2007 12:48 AM
alexisthemovie
Feb 22, 2007 06:01 PM
NETAMI
Mar 19, 2006 06:45 PM
ultimatehonda
24
Sep 19, 2005 10:27 AM
