Is my timing off or is it something else
Old Jun 1, 2004 | 03:58 PM
hybrid1990crx's Avatar
Default Is my timing off or is it something else
OK, headgasket is replaced, nothing is leaking, the bitch drives.
Heres the problem. The car drives fine. But when it gets around 4,000 is starts making a strange noise from the intake, like a gagagagagagaga but really fast, along with the normal sound the intake makes. And I'm definetly not making the power up there like I should be. Im about to replace the cap, rotor, and get new plug wires, just because it cant hurt anyway. I got NGK plugs and gapped them to 1.1 like I said, but I may have gapped them a bit off due to me being really tired after working on my car for 10 hours straight.
So could it be:
-Cap and rotor
-Plug wires
-Incorrectly gapped plugs
-Timing is off
I pulled off my cap and I saw that its a bit corroded(sp?) and the rotor looks a bit burnt or something. So i sprayed it down with carb cleaner (cause that **** will take the tar off your driveway LOL) and cleaned it up kinda nice. But its still kinda odd looking.
And also, I looked in my manual and I couldn't find it anywhere, and this is probably going to sound dumb, but how do I take off my rotor? I dont see any screws or anything holding it in and I don't want to dive into it and end up breaking something. So if someone could fill me in on that, I'd greatly appreciate it.
Thanks guys! Hope to have her running 100% by the weekend.
Old Jun 1, 2004 | 04:03 PM
paybac4223's Avatar
Default Re: Is my timing off or is it something else (hybrid1990crx)
sounds like up may be missing(misfire) up top....i would tell you to check the timing and plug wires..... make sure that the new plugs are tight...
everythingwentblack
Mar 26, 2009 11:21 PM
xXx Justin xXx
Jun 9, 2008 06:44 AM
`chrisb
Apr 29, 2008 08:31 PM
HavokB18
17
Apr 21, 2003 03:44 PM
