Sport Seat
Old Nov 11, 2001 | 12:04 AM
IwanAturBo's Avatar
Default Sport Seat
Have u guys ever tried to put those racing or sport seats into a 90-93 accord??? i mean for those who have the electrical seat beat ****.. if so how is ure setup?? thanks...
Old Nov 11, 2001 | 01:36 PM
4doorRS5spd's Avatar
New User
Default Re: Sport Seat (Hydr0tUrb0)
I assume that you will disconnect the electrical connectors from under the seat and take the seat out like normal. Make sure the sport seat has the correct brackets for your application and you'll be good to go. That's if you are talking about a power seat, you know, one that you control the position of with the push of a button.
Or, are you talking about those power seat belt things. I assume you will just disconnect the belt. You won't be using it anymore anyway. (If it's like my 5th gen, the seat belt connector is built into the seat you are removing.) You'll want to get some kind of harness, like a 4 pt.
Old Nov 11, 2001 | 03:38 PM
Conechaser's Avatar
Default Re: Sport Seat (accord55)
I just installed a Corbeau Seat in my car. It had the power up/down on it. You lose that w/ the race seat. The seatbelt unbolts from your stock seat and bolts onto the rail for the new seat, then you just plug it back in. You can not use a harness on the street it is illegal, you will get a ticket for no seatbelt
Old Nov 11, 2001 | 09:28 PM
IwanAturBo's Avatar
opps... i did a typo.. it was suppost to be seat belt.. anyway.. yesterday i took the seats out and the problem was.. the seat belt is mounted onto the oem chair.. i disconnected the harness from the seat belt and the chair at the bottom but there is a warning sound that is aggravating ... so i haf to reconnect the harness... u guys ever install a seat into a 91 accord se?? or ex?? thanks
TakeCarDaddy
Honda Civic (2006 - 2015)
Oct 25, 2018 10:16 AM
GThonda
Jul 6, 2010 07:22 AM
bmcp.
Sep 28, 2009 09:37 PM
twentyhurtz
10
Dec 5, 2008 09:36 AM
soberstan
12
Oct 22, 2004 12:01 PM
