starter motor
Old Jun 1, 2004 | 02:18 PM
IVI's Avatar
IVI
Default starter motor
how much is a starter motor? do all b-series starters all fit the same? how about all honda starters? civic starters 92-95? or any others. is anyone selling one for cheap?
Old Jun 1, 2004 | 02:46 PM
ndustryalGSR's Avatar
Default Re: starter motor (IVI)
If it's just the case that your current starter is dead, you can remove it and take it to a starter/alternator shop to be rewound. When you get it back, it's practically good as new. In the past, this has cost me between $20-$40 -- certainly less than a new unit. Usually, you get a warranty with this work, too.
Removing and refitting the starter is pretty straight-forward, but be warned: some of the bolts are reeaaalllllyyyy looooonnnnngggggg.
Good luck. Should be an easy fix
Tim 59
Honda Civic (2006 - 2015)
Sep 1, 2010 10:30 AM
Importracer_001
Sep 6, 2009 04:49 PM
Mdg5858
Feb 9, 2009 12:08 PM
