Testing a coil
Old Jun 1, 2004 | 01:43 PM
ImportHatch's Avatar
Default Testing a coil
This is not a honda but I thought you guys might be able to help. Is there anyway to test an external coil, like with a battery? I'm trying to figure out why I can't get spark in my 78 toyota and I would like to find out if the coil is bad before I buy one. Thanks in advance.
Yager-
Old Jun 1, 2004 | 02:12 PM
Default Re: Testing a coil (ImportHatch)
ttt
Old Jun 1, 2004 | 07:59 PM
LSVTEC 91 Civic's Avatar
Banned
Go to Autozone, they'll test it...
Old Jun 1, 2004 | 08:35 PM
Simple's Avatar
Default Re: Testing a coil (LSVTEC 91 Civic)
try starting the car with your fingers on it.... if it hurts like hell, you're good to go
Old Jun 1, 2004 | 10:58 PM
Default Re: Testing a coil (Simple)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Simple &raquo;</TD></TR><TR><TD CLASS="quote">try starting the car with your fingers on it.... if it hurts like hell, you're good to go</TD></TR></TABLE>
Well I already know I don't have spark but if I didnt that might work...
Yager-
Old Jun 2, 2004 | 04:35 AM
BigMoose's Avatar
First measure the coil resistances with your ohmeter. Check against spec. The primary of modern, fast rise time coils, will be very low, around 0.6 ohm. You wont be able to read that well without a specialized low ohm ohm meter. Check with the ohm meter for any shorts to the metal case or the exposed laminations (if this coil has them.)
Now modern fast coils have current limiting coil drivers, so do this with care, cause this method does not accurately limit coil current.
Grab a lead from the battery, put it thru a normal 12v incandescent headlight (use this to limit current) put your lead from the headlight to the + terminal on the coil. Place a lead or a spark plug with a 0.100 gap on the secondary and ground it to this + terminal. Now take a bastard file and ground it. Take a lead from the - of the primary coil and QUICKLY scrape it along the file, you should get a lot of sparks.
torr
Apr 24, 2024 09:35 AM
boostnubII
Oct 23, 2006 12:39 PM
aalb1
Aug 8, 2005 03:04 AM
oMek
Jan 22, 2005 07:17 PM
