Race Gas
Old Jun 1, 2004 | 11:58 AM
Importracer_001's Avatar
Default Race Gas
Whats up,
I new to this **** so help me out
I'm about to get a Wide band meter so I can tune my B16turbo with AFC hack
I wanna boost something like 10-11 psi but I will use Race Gas I'm gonna use ELF moto 124 ,they told me this is more than 116 octane fuel ,since I cant get C16 or something like that anywhere here ( netherlands)
Is there a difference in reading the Wideband when I use regular fuel and the Race Fuel
Hope you guys can help me out with some advice
By the way I'm using stock ignition my sparkplug gaps are now 0.030"
Old Jun 1, 2004 | 01:49 PM
Speedworks801's Avatar
Default Re: Race Gas (Importracer_001)
No difference in reading the wideband applies as long as you are using gasoline. If you use an "alternative fuel" like methanol, for example, you use a different ratio scale. Otherwise, happy tuning!
Old Jun 1, 2004 | 03:26 PM
H2nr's Avatar
Default Re: Race Gas (Speedworks801)
you dont need race fuel for 10psi, unless you just dont like your o2 and want to burn it up
Old Jun 1, 2004 | 05:44 PM
BOOSTIN1's Avatar
Default Re: Race Gas (H2nr)
hay i got a question,does race gas go bad?
Old Jun 1, 2004 | 05:52 PM
ModenaTwinTurbo's Avatar
Default Re: Race Gas (PBOOSTIN)
i believe it does... after a while... and i've herd i dont know how true this is... but i've herd that if you store it on the floor contained in a plastic containter it can also go bad easyly...someone correct me if i'm wrong please..
Ed-
Old Jun 1, 2004 | 06:05 PM
alternativeauto's Avatar
Default Re: Race Gas (ModenaTwinTurbo)
Damn, hope thats not true. If so I am depriving my lawnmower and 4 wheeler of the full potency of my left-over 112.
Old Jun 1, 2004 | 06:07 PM
SadisticRacing's Avatar
Yes race gas can go bad. I've always been told to store it in an air tight container to help it stay longer. If not I was told four months tops.
Old Jun 2, 2004 | 03:37 AM
I'm using the AFC hack and since I dont have another management system I wanted to boost a little more I ran on 9 psi now I wanna try something like 11 psi I dont wanna detonate and blow my B16 right now
Old Jun 2, 2004 | 03:05 PM
Paisley's Avatar
How much is that Elf fuel?
Old Jun 2, 2004 | 03:28 PM
Default Re: Race Gas (Paisley)
Says here its for 2 stroke applications http://www.racecar.co.uk/elfra...s.htm
Feul by little people for little cars, manufactured in big trees. Kinda went to far with that one .
Old Jun 3, 2004 | 09:18 AM
H2nr's Avatar
if you dont want your engine to blow buy Hondata or some other system. taking the cheaper easier way out is never cheaper in the end.
95exdsmkilla
Feb 20, 2008 09:13 PM
^AnDre^
11
Aug 15, 2005 02:53 PM
RedTT
Sep 22, 2004 04:07 PM
88CRXHybrid
May 28, 2002 07:22 PM
ActiveAero
Sep 24, 2001 08:10 PM
