Toda "B" ITR owners: what are your cam gear settings?
Old Nov 10, 2001 | 10:29 PM
BlackGSR's Avatar
Default Toda "B" ITR owners: what are your cam gear settings?
Just taking a poll. What are you cam gears set at with your Toda "B" cams?
My cam gears are tuned for the GSR manifold. I now have a Skunk2 manifold (plus some other goodies) ... and would like to adjust the cam gears w/out going to a dyno.
Yes, eventually I will hit up a dyno ... just not yet.
Old Nov 11, 2001 | 06:45 AM
EPGONZALEZ's Avatar
Default Re: Toda "B" ITR owners: what are your cam gear settings? (BlackGSR)
i would leave them at zero until you can get to a dyno..you wont know if the setting is helping or hampering your performance...
Old Nov 11, 2001 | 08:58 AM
Maxi's Avatar
Default Re: Toda "B" ITR owners: what are your cam gear settings? (EPGONZALEZ)
I was running +3 intake and +1 exhaust (195 whp prior to recently having my engine rebuilt), but I haven't had a chance to retune everthing since the rebuild so I can't say for sure this is where I'll end up again. The cams are back at zero for the break-in period. I've heard from several experienced tuners that +4 IN and +1 EX works well for them on most built Toda B engines, but I won't have a chance to test this set-up for another month or so.
Best of luck with your tuning,
Dave
Old Nov 11, 2001 | 09:10 AM
Black R's Avatar
25 Year Member
Well, definitely take EP's advice and do your tuning on the dyno...
But I've got +2 in, 0 exh as my settings right now.
I'll definitely change this on the dyno soon.....
I've heard that only +1 or so on the exhaust will do anything, whereas advancing the intake +2 at a time until you start to lose power is a good option... I'll try to locate a file I had on tuning from jeff @ importreview...
Old Nov 11, 2001 | 04:51 PM
Mike K's Avatar
Default Re: Toda "B" ITR owners: what are your cam gear settings? (Black R)
On a ITR motor w/ Endyn 12:1 pistons and a Mugen header.. stock ECU w/ 270cc injectors, best setting was +5, +5
With 310cc injectors, Skunk2 ECU added... best setting was +7, -2
Weird cams. They respond to some things, and then they don't.
Old Nov 16, 2001 | 04:32 AM
Mike K's Avatar
Default Re: Toda "B" ITR owners: what are your cam gear settings? (Mike K)
ttt
I'm interested still in more responses from this topic.
I'd like to know others settings and their results.
Old Nov 16, 2001 | 06:07 AM
Black R's Avatar
25 Year Member
.....oh yeah to add another variable to the equation:
If your head is milled or you have head work this may affect the settings as well...
The only people I've seen benefit from advancing the exh cam had some headwork and this effectively brought it back to +1 or 0... Most have a setting of +1, 0, or -1 on their exhaust cam, and +4 or more on the intake cam with spec b's in a mostly stock motor and stock compression... From what I've seen.
Old Nov 16, 2001 | 08:54 AM
Big Phat R's Avatar
I run +4 in +1 ex
Using a milled head or thin head gasket will advance your ignition timing and affect cam timing as well. Thus you need a dyno to really find the sweet spot.
Old Nov 16, 2001 | 09:00 AM
B18CXr's Avatar
Advance the **** out of the intake gear and play with the exh. till the power is where you want it.
Old Nov 16, 2001 | 09:05 AM
VTEC4GS's Avatar
most of the times after I degree the cams, I get the +7-10 degree advance range for Intake cam and retard exhaust about 1-4 degrees.
obviously by degrees I mean each index mark, so its twice that at the crank for aem, skunk2, unorthodox gears and 1/2 of each mark for JUN gears, etc.
On the Toda gears it works differently, so use the 105 degree intake setting and 95 exhaust.
Greg
Old Nov 16, 2001 | 09:17 AM
Austin's Avatar
Default Re: Toda "B" ITR owners: what are your cam gear settings? (vtec4gs)
My current settings are:
Intake: +3.5 crank
Exhaust: +1.0 crank
These worked best for the flat torque curve that I wanted.
Austin
honda_mike
Apr 6, 2009 08:29 PM
scribnits
Apr 23, 2002 01:06 PM
Aar99GSR
Mar 3, 2002 11:17 PM
Maxi
Nov 9, 2001 10:37 AM
