Compisition of OEM rings
What are OEM rings made out of? The machinist I was working with wanted to know if I was using chrome, moly or cast. He said it affects how he hones the cylinders. Chrome and moly are different? I thought I've heard of chromoly?
-PHiZ
-PHiZ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ »</TD></TR><TR><TD CLASS="quote">What are OEM rings made out of? -PHiZ</TD></TR></TABLE>
I'm pretty sure stock OEM honda rings are CHROMEMOLY MAGNESIUM........
OE B18 rings are a steel top ring with a chrome plated barrel face.
The second ring is a napier style (has a cut on the bottom outer edge) cast iron ring.
The oil ring is a 3 piece deal with a expander that waves in and out as opposed to up and down like a Hastings flex vent.
Generally OE Honda rings require a very smooth bore finish as prescribed by the Helms manual.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rocket »</TD></TR><TR><TD CLASS="quote">OE B18 rings are a steel top ring with a chrome plated barrel face.
Generally OE Honda rings require a very smooth bore finish as prescribed by the Helms manual.</TD></TR></TABLE>
You see, OEM yO!
You see, OEM yO!
sander
Mar 29, 2004 09:45 AM
