DYI valve cover paint procedure
Old Jun 1, 2004 | 11:09 AM
flashmang's Avatar
Default DYI valve cover paint procedure
hey guys...
looking for some advice on painting my valve cover.
1. im assuming that i will need some sort of high temperature paint to begin with?? any idea's on where to get this??
2. can the cover be taken off, painted, and put back on without replacing the gasket??
3. what should i tourqe the bolts to once i put it back on and do they need to be tightend (or untightend) in any certain order??
4. what is the best method of not painted the letters?? i originaly thought about just putting some good paint tape over the letters and cutting it out with a razor blade, but a friend told me to use vasaline?? does that really work??
5. any thing im missing??
if this thread gets a good turnout i will post pictures of the cover once i finish it. thanks guys
[IMG][/IMG]
Old Jun 1, 2004 | 11:11 AM
flashmang's Avatar
Default Re: DYI valve cover paint procedure (flashmang)
i was going to post the before picture of the valve cover but when i hit insert image it just puts wierd letters down. is this because im still a trial user ?
thanks again
Old Jun 1, 2004 | 12:12 PM
JTCdudeman's Avatar
Master H Technician
heres what to do.. First off, go to your local cheapo supply store... Walmart or some other store such as.. Then, go to the paint section.. Pick up some paint stripper! This stuff works great... Its a spray paint like can... Then, find some high temp paint... should be easy enough.. also your autozones and such will have it if ya cant find anything at walmart or such... Then, you should be good to go...
1.Buy paint
2 Remove valve cover
3. strip paint
4. polish vtec aluminum
5.vaseline vtec
6.paint cover
6.5 rub off vaseline
7replace cover w/ original gasket!(should be fine)
8 hand tigthen bolts.. anymore and you will break them off...
9 stare in amazement
Old Jun 1, 2004 | 12:16 PM
Behan's Avatar
here are 2 diy threads
https://honda-tech.com/zerothread?id=798923
https://honda-tech.com/zerothread?id=782937
i personally found it easier too just paint the letters and sand them down afterwards.
flashmang's Avatar
Default Re: DYI valve cover paint procedure (JTCdudeman)
this is good information...
anyone else have any idea's especially on re-tighting the bolts, i heard one dood who did it by hand broke some bolts plus cracked the the cover. definately do not want to do that. is there a set tourqe they should be at??
felixjr18
Paint and Body
Apr 29, 2009 11:07 AM
Hexonxonx
May 24, 2004 08:14 AM
Chemicalviper
Dec 17, 2003 01:12 AM
ih8danoles
Oct 27, 2002 01:22 PM
vtec_powah
Sep 16, 2001 01:19 PM
