Where can i buy a Tial 35mm wastegate gasket?
Old Jun 1, 2004 | 10:20 AM
Dracord's Avatar
Default Where can i buy a Tial 35mm wastegate gasket?
Anyone? The gasket on mine is blown and i need to get a new one
Old Jun 1, 2004 | 10:21 AM
MikeMAN's Avatar
Default Re: Where can i buy a Tial 35mm wastegate gasket? (Dracord)
don't run one..
mike
Old Jun 1, 2004 | 10:29 AM
Dracord's Avatar
How come? I don't know the benefit or why i would i would go without...just so it doesn';t keep blowing out?
After about 15 calls i just found out importparts.com sells them and i ordered one.
Nameless RB26's Avatar
Default Re: Where can i buy a Tial 35mm wastegate gasket? (MikeMAN)
egay
Old Jun 1, 2004 | 10:35 AM
MikeMAN's Avatar
Default Re: (Dracord)
you dont need one, make sure both surfaces are clean and flush before mounting and you will be fine. you will just end up blowing out the gasket you just purchased again.
mike
Old Jun 1, 2004 | 10:48 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dracord &raquo;</TD></TR><TR><TD CLASS="quote">Anyone? The gasket on mine is blown and i need to get a new one
I have a 38mm one if that will work....
Old Jun 1, 2004 | 10:57 AM
5STAR3's Avatar
Default Re: Where can i buy a Tial 35mm wastegate gasket? (4-banging)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4-banging &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 38mm one if that will work....</TD></TR></TABLE>
a 38mm will work.
but if i were you i would not run one.
Old Jun 1, 2004 | 10:59 AM
TeamCracka's Avatar
Default Re: Where can i buy a Tial 35mm wastegate gasket? (envision2teg)
Copper Spray!
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">
a 38mm will work.
but if i were you i would not run one. </TD></TR></TABLE>
what are the ill effects of <U>running</U> one? I have one on mine and no problems I have seen as of yet??
Old Jun 1, 2004 | 11:08 AM
MikeMAN's Avatar
there are no illeffects of running one, you will just be replacing them over and over again, they are unncessary
mike
Old Jun 1, 2004 | 11:12 AM
4-banging's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeMAN &raquo;</TD></TR><TR><TD CLASS="quote">there are no illeffects of running one, you will just be replacing them over and over again, they are unncessary
mike</TD></TR></TABLE>
so after the gasket goes, it would be safe for anyone to not run one after that...right?
Old Jun 1, 2004 | 11:17 AM
flip1199's Avatar
i ran mine with the gasket and after 2 weeks it was toast. then i ran without it and had no problems for the 2 months the car was running after that
Old Jun 1, 2004 | 11:19 AM
MikeMAN's Avatar
correct sir
mike
Old Jun 1, 2004 | 11:30 AM
4-banging's Avatar
correct sir
well, "Dracord" try it out? I probably will after mine goes...
Oh yea, what are the tell-tell signs that your WG gasket crapped out on you?
Old Jun 1, 2004 | 11:37 AM
MikeMAN's Avatar
Oh yea, what are the tell-tell signs that your WG gasket crapped out on you?</TD></TR></TABLE>
probably an exhaust leak right where the WG + flange meet...put your hand there, should be nice and warm haha
mike
Old Jun 1, 2004 | 12:20 PM
yellowturbo's Avatar
just put *nothing* and it will be fine if the 2 surfaces are straight and clean...I always used this method... even between my turbo and my manifold... I just put a lil bit of red hi-temp silicon to prevent rust between the two surfaces !
Old Jun 2, 2004 | 07:08 AM
Dracord's Avatar
I'll try that after this next one blows out. I bought the turbo used and gasket was blown. The wastegate was warped so i had that and the manifold decked, then ordered new gasket to put on.
The only reason i noticed it because there was bits of burned gasket hanging out. I already ordered one for 10 dollars. I dunno what i'll try yet. Thanks for the info guys
Old Jun 2, 2004 | 10:19 AM
J337_UNIT's Avatar
i used a thin layer of copper silicone.. no problems what so ever
Old Jun 2, 2004 | 04:57 PM
pip9's Avatar
Default Re: (J337_UNIT)
$10?? I have an extra one laying around that i am not going to use. If i would have seen this thread earlier i would have gave u a much better deal. My gasket blew out on me after like 1k miles.
running gasketless now w/o any problems that i know of
Turbo_Mike
Aug 25, 2005 06:55 AM
Vinhtran17
May 12, 2004 02:21 PM
SpeedMonkeyRacing
Oct 9, 2003 12:33 PM
Mr. Vapor
Aug 24, 2003 02:16 PM
Rain_man
May 9, 2003 03:32 AM
